Accessories turn on after door is locked???
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Accessories turn on after door is locked??? in Cadillac Escalade Forums; I have a 2005 Escalade base. Recently the entry remote has stopped working, I think it might be the battery ...
    ptippett is offline Cadillac Owners Member
    Automobile(s): Escalade
    Jun 2009
    14
    I have a 2005 Escalade base. Recently the entry remote has stopped working, I think it might be the battery but have not yet replaced. Then yesterday when I locked my door and shut it the lights on the ibehind the glove box nstrument panel were flickering and I heard a relay behind the glove box clicking with the lights. I disconnected the battery for two hours and tried again. this time I locked the door, 20 seconds later the lights dimmed and went out, then the instrument cluster lit up and the GPS/Radio turned on. It was like someone turned on the ignition. I disconnected the battery again, let it sit overnight, and have the same experience.
    When door is locked and shut
    Lights dim and turn off after 20 seconds
    then the car ignition is turned on
    Any suggestions on what could cause this?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by ptippett
    Sounds like the bcm as that is what works the dash or possibly the harnesses in the steering column
