Troubleshooting pop in front end
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Troubleshooting pop in front end in Cadillac Escalade Forums; I have recently purchased a 2002 escalade ext and when I back up or turn sharp a feel a pop ...
    tgardner is offline Cadillac Owners Member
    Automobile(s): 2002 escalade ext
    Mar 2013
    1
    I have recently purchased a 2002 escalade ext and when I back up or turn sharp a feel a pop in the front left wheel. Not sure what it can be but I have found some documentation that points to several different causes but none definitive on what the cause is or how to diagnose. I have read about the transfer case, cv joints, ball joints, or tie rod ends. Can anyone help me with pinpointing what might be causing the issue?
    6lbsofSound is offline Cadillac Owners Fanatic
    Automobile(s): 03 Escalade
    Aug 2012
    193
    Re: Troubleshooting pop in front end
    Jack up the front end and grab the wheel by 3 & 9 o'clock and see if there is play. Then grab the wheel 12 & 6 and see if there is any play. That should check for the rod ends and ball joints. As far as CV joints and transfer case is concerned you need to look and see if there is excessive movement.
    Do you have a shake or vibration while driving?
    Txao1051's Avatar
    Txao1051 is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Feb 2013
    29
    98
    Is there ice on the ground? I feel it all the time but its mostly when. I slip on the ice
