Rattle In Muffler
Results 1 to 14 of 14
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rattle In Muffler in Cadillac Escalade Forums; My 2006 has a rattle emitting from inside the muffler. Sounds like something came loose inside. Should I replace, ignore, ...
    oldrunner is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade ESV
    Jan 2013
    73
    30
    Rattle In Muffler
    My 2006 has a rattle emitting from inside the muffler. Sounds like something came loose inside. Should I replace, ignore, replace myself or have it done?
    Thanks
    TheCaddyKidd's Avatar
    TheCaddyKidd is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 Cadillac Escalade EXT
    Sep 2003
    New Jersey
    31
    2,090
    Re: Rattle In Muffler
    Quote Originally Posted by oldrunner View Post
    Thanks
    Is it actually coming from inside the muffler or do you just hear it from inside the cabin and assume it is coming from inside the muffler? The reason I ask is that on my mom's 02 she had a rattle that we heard everytime you revved the engine.. Turns out the heatshield came loose..
    Thanks
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by TheCaddyKidd
    My 03 had the heat shield come loose on the muffler and took a couple hose clamps to fix it(no more rattle while driving(side note make sure the clamps are coupled or they won't fit)
    Jan 2013
    73
    30
    We put it up on a rack and could hear the rattle coming from inside the muffler.
    Mar 2011
    speedwell tn,
    11,884
    Time for a new one then
    Jan 2013
    73
    30
    Any recommendations on brand of replacement, quiet to mellow sound...
    Jan 2013
    73
    30
    It's going away. Forgot to mention I had the transmission replaced last week and it was shifting very hard at first. It's been installed 5 days now and the shifting has really smoothed out and the muffler rattle has gotten progressively better. I'm thinking now the new transmission was vibrating because it wasn't broke in and now that it's had some breaking in and the shifting is smoother the vibration is less and the rattle is almost all gone. At least that's what my old feeble mind is thinking.
    Thanks
    Mar 2011
    speedwell tn,
    11,884
    Thanks
    I still suggest crawling under the truck to be sure a weld hasn't broke on the shield
    Jan 2013
    73
    30
    Found It! Kept looking for a loose heat shield and found the forward muffler clamp (probably not OEM) was not tightening properly. I couldn't get it to tighten enough so I wrapped a stainless steel hose clamp around it to test it and voila, no rattle. Plan on taking it to a muffler shop and have them fix it right. Thanks for the help.
    Mar 2011
    speedwell tn,
    11,884
    Glad to help(I know the rattling noise can drive you crazy after a while I put up with mine doing that for a few months before I did something and it made me wish I had done it sooner)
    Cyco's Avatar
    Cyco is offline Cadillac Owners Member
    Automobile(s): 06 Escalade
    Dec 2004
    Green Bay, WI
    41
    Just a heads up I also had a rattling noise and it ended up being a bad Catalytic Converter.....
    Vintage56 is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade base 2wd
    Apr 2013
    Mustang, OK
    38
    14
    btt
    Cyco,
    with your bad Cat, did you get a check engine light (DTC) and if so, do you know if it was P0430?
    the wife's 06 Esky got congestion from the passenger side a few weeks ago and I noticed the dummy light a couple days ago.
    just pulled the code and it looks like I'm in for new converter(s). What did that cost you? OEM or aftermarket?
    my research is in full swing...
    JML
    Cyco's Avatar
    Dec 2004
    Green Bay, WI
    41
    Quote Originally Posted by Vintage56 View Post
    btt
    Cyco,
    JML
    Yes, check engine light came on. I want to say when we ran the code it mentioned "bank1" or "bank2". Was the driver side CAT. I went to Fair Muffler for $300 bucks, they put aftermarket on, and it is fine. They also reset code.
    C
  16. #14
    Apr 2013
    Mustang, OK
    38
    14
    Dropped the wife's Esky at the muffler man's place this morning.
    confirmed the deep rattle was a bad bank 2 cat converter. Engine code was P0430
    note for others, a tinny rattle would be more indicative an aluminum heat shield.
    this sounded deeper and kind of hollow.
    JML
  17. Remove Advertisements
