Antenna amplifier
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Antenna amplifier in Cadillac Escalade Forums; Has anyone tried an amplifier or booster of fine kind for the FM reception? I recently put an aftermarket HU ...
    CaddyEscalade is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    May 2010
    231
    Antenna amplifier
    Has anyone tried an amplifier or booster of fine kind for the FM reception? I recently put an aftermarket HU and the FM reception sucks. Any suggestions? Thanks
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,812
    Quote Originally Posted by CaddyEscalade
    Just fyi I've seen defective headunits do this, even on some the am was better than the fm
    May 2010
    231
    Interesting, where is the antenna on a 2003 caddy, as on the 2005:2006 there is a normal black antenna on the passenger side hood cowl. Is it integrated with little rubber one for onstar on the roof?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    The only antenna I have seen for the radio on the escalade base and esv is in the rear side windows the amp is right above the right rear window along with a impedance matching module above the left rear window but you have to drop the headliner to access it
    I suggest trying a different radio before I'd mess with the antenna
    The only model I have seen that has a whip style antenna is the ext
    Most times its the radio
    dssrocks is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade Ext.
    Mar 2009
    43
    74
    Re: Antenna amplifier
    Quote Originally Posted by the cadillac man View Post
    Yea you are right it was an EXT that I was looking at. This antenna system sucks on the regular escalades.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by dssrocks
    No it don't I know as I can get stations better then a standard whip antenna(it just sucks to work on)
    But most aftermarket radios don't work good with certain setups(my previous car had the antenna in the rear window worked great with the stock radio not so well with a aftermarket radio)
  9. Remove Advertisements
