Service ride control - 2002 Escalade
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Service ride control - 2002 Escalade in Cadillac Escalade Forums; I own a 2002 Escalade. My "service ride control" message is on. Can anyone tell me what that's means? How ...
    AnthonyBlan is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Escalade
    Feb 2013
    Elk Grove, Ca
    1
    I own a 2002 Escalade. My "service ride control" message is on. Can anyone tell me what that's means? How do I fix it? And how much does it cost? Thanks for any feedback.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Service ride control
    On an STS it would mean replacing some very expensive shocks. YMMV!
    Cadillac Kid03's Avatar
    Cadillac Kid03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Cadillac Seville SLS
    Mar 2011
    Tinton Falls, NJ
    25
    1,299
    That's for sure!!^^^
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,768
    Go to a local autop parts store, and borrow their code reader. Write down the codes, look up their definitions and post them here.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,126
    Let's move this from the chit-chat Lounge to the proper year Escalade forum. Please read the text in a forum title box to find out what gets posted where. Thanks.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by AnthonyBlan
    Most likely the compressor has failed but you need the codes to be sure
    djais1801's Avatar
    djais1801 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 EXT Sable Black
    Feb 2011
    NJ
    47
    246
    Re: Service ride control - 2002 Escalade
    x2 cadillac man...in my case, it was the rear air shocks that needed replacing...you should be able to hear the compressor cycling on/off. it's located just behind the driver side rear wheel well.
    Drmorgan is offline Cadillac Owners Member
    Automobile(s): 2003 AWD Escalade
    Mar 2013
    Salt Lake, UT
    51
    Anthony, I have a 2003 Escalade that I purchased just a year ago. I recently started getting the same message. I went to change the oil my self for the first time, and when I crawled underneath the vehicle, to my surprise, there is grease zerks all over underneath that i was not aware of and so I greased them and now the message is gone. I figured this being a Caddy, it would have non-greaseable suspension (ride control), but it has quite a few. After greasing the zerks and finishing my oil change, I took it around the block and restarted it a couple times and never saw the message again. I found 3 zerks on each front tire suspension. Hope this helps.
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    351
    there are 11 zerks.
    Upper ball joints- 2
    Lower ball joints- 2
    Tie rod -4
    Steering arm - 1
    Idler arm - 2
    Dave Martinez is offline Cadillac Owners Member
    May 2014
    1
    What if you replaced all 4 shocks, is there a reset on this error?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Year old thread.
    Several things can trigger the message, you have to have your codes pulled.
    And no, there is no "reset". OBD sees a problem, and it will display the message until it's fixed.
  14. Remove Advertisements
