05 ESV front AC/heater only blows sporadically...
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 05 ESV front AC/heater only blows sporadically... in Cadillac Escalade Forums; Brand new to this forum so I apologize if this has already been posted. My 2005 Escalade ESV has issues ...
    Ivabgn is offline Cadillac Owners Member
    Automobile(s): 05 ESV
    Feb 2013
    8
    My 2005 Escalade ESV has issues with ONLY the front AC/heat blowing. It trickles out, but will work only when it feels like. The rear works just fine.
    Any helps is greatly appreciated!
    Thanks
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Ivabgn
    Brand new to this MB so I apologize if this has already been posted.
    Thanks
    Are you talking about water under the truck when the ac is running if yes then that is normal
    Also welcome to the forum
    Feb 2013
    8
    Re: 05 ESV front AC/heater only blows sporadically...
    Sorry, I should have been more specific. The blower itself on the front AC/Heat only blows on occassion. The rear AC/Heat blows all the time as it should. I am curious as to if it is the front blower itself that needs to be replaced or if it is a relay. Thanks
    Mar 2011
    speedwell tn,
    11,884
    Blower control module needs replacing in the front not the blower
    Feb 2013
    8
    WOW thanks! What a great resource you are to have. Can you tell me where it's located and how difficult it is to change out? Thanks again!
    Mar 2011
    speedwell tn,
    11,884
    Passenger side under the dash
    Remove the kick panel(three screws)
    And it is next to the blower(if not follow the wires from the blower) on the bottom far right
    Feb 2013
    8
    Quote Originally Posted by the cadillac man View Post
    Thank you. You just saved me some money!
    Brandi126 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Escalade
    Feb 2013
    York, PA
    33
    4
    Welcome, I myself am new as well and have found quite a bit of information to be helpful. While you have an ESV, I have I guess just the standard model AWD.. I had this same problem (amongst others) for quite sometime until I finally today purchased a Blower Motor Resistor. I never figured out why it was doing it until I messed around with this part which is in the black casing underneath your glove box. When it wouldn't blow, moving the resistor made it come on. Fairly cheap part. Hope this helps!
    Feb 2013
    8
    Quote Originally Posted by Brandi126 View Post
    Thanks for your help. I'm going to try and find the part tomorrow and change it out. I just hope someone has it in stock.
    Feb 2013
    8
    Thank you to everyone. Worked like a charm and only cost me $169 and 5 minutes of time.
    Mar 2011
    speedwell tn,
    11,884
    Glad to help
  14. Remove Advertisements
