LED Rear lights
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, LED Rear lights in Cadillac Escalade Forums; I know a few of you have these fitted and was hoping one of you would have the time to ...
    John P is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Escalade 6.0
    Feb 2009
    Glasgow, Scotland
    159
    LED Rear lights
    I know a few of you have these fitted and was hoping one of you would have the time to video the lights on and the various functions I.E turn signal, brakes etc.
    I'm looking at the red/clear stock looking ones but I believe they all function the same.
    Thanks guys.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by John P
    Thanks guys.
    Which model of escalade do you have I have the base model and have led taillights and they work great
    I also have a few pics and a video of how they look if you want me to email them to you
    Mine is the clear lens version with red LEDs
    Feb 2009
    Glasgow, Scotland
    159
    Hi, It's a 05 base model i have.
    That would be great if you could send me them, Just for me to see how they function.
    My email is j444hnp@googlemail.com
    Thanks again for that, Very much appreciated!!!
    Mar 2011
    speedwell tn,
    11,884
    Ok I will send the pic and video
    Update pics and video sent
    Also here is where I got them
    Www.carid.com
    Feb 2009
    Glasgow, Scotland
    159
    Re: LED Rear lights
    Thanks Cadillac Man, been meaning to come on and thank you. Good of you to take the time to do that! Cheers
    Mar 2011
    speedwell tn,
    11,884
    Your welcome I am always glad to help
    Eric1975 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV
    Mar 2013
    41
    1
    Re: LED Rear lights
    Hi all, I'm new here. Cadillac man, would you be kind enough to e-mail me the video? I'm considering going LED and was wondering if you had any problems with a fast blink after you switched? I've read that adding a resistor solves the problem. Ericoverlie@gmail.com
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Eric1975
    Email sent the resistor is only needed if you use led bulbs(which I will be using for the front blinkers)
    Sapphire83 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac escalade
    Mar 2013
    1
    Re: LED Rear lights
    05 Escalade
    Hi I have the led tail light but the brake light is not working on the passenger side. All the other lights (turn signal/running) work but not the brake light...where can I start looking & if a replacement is necessary can I replace just the bulb or the whole taillight?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Sapphire83
    05 Escalade
    Could be connections or bad taillight
    Try a regular bulb in each socket and see if it works if yes then the problem is in the taillight if no then the problem is in the truck
    Romulus1 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Escalade
    Nov 2012
    31
    Re: LED Rear lights
    I gotta chime in too, which LED tails do you have cadillac man? I have the CG ones and i went and hooked em all up, plugged everything in on the d/s. no illumination on that d/s but stock stuff stayed lit on the p/s. so i swapped in the p/s also and my fuses both blew. Switched em back to stock and the p/s still keeps blowing. I tried flipping connections before the fuses went and all cuz i know LED's can use that, not sure about these ones but i tried anyway. Any thoughts?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Romulus1
    Ouch that sucks I will look and see if I can find out the brand mine is and post the link for you as it sounds like you have a bad set
    If you can post a pic of them and how they hook up as mine uses the factory lamp sockets and is plug and play
    Edit mine are also the cg ones in clear with red LEDs and are plug and play
    Nov 2012
    31
    Re: LED Rear lights
    sorry to thread jack, though it is an old thread. i think ours might be the same, i saw you reply in another LED where someone swapped to the same as mine.
    I attached them exactly how CG's website says, remove old housings, pull bulbs. plug new connectors into sockets making sure the green wires go to green and black to black, put it all back together and then re installed the housing. I had no illumination, unfortunately i dont have my volt meter or my test light so i cant check the power going in just in case but i know they drew power at one point since it blew both fuses. unfortunately it was too much power. After i did that i flipped all the wires and no luck again. left them installed the original way with the green to green, black to black. i put them back in for the day in the event CG returns my call.
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=128946"/>
    Sounds like the gray box is bad or the circuit board inside the taillights is bad as they are plug and play and shouldn't blow any of the fuses in the truck
    Which fuse did that blow as that indicates a short in the circuit as the fuse protects the wiring from burning up in cases like this
    I know mine has three plugs one for tail and turn one for tail and brake and another for the peanut marker light socket
    Gribblet likes this.
  17. #15
    Nov 2012
    31
    Re: LED Rear lights
    same as mine, and it reuses the factory reverse. I'm gonna give CarID a call and see what they say to me
    EDIT: i lied i order through new egg, the company is shipping me new resistor packs first thing tomorrow.
    I'll keep you posted
  18. Remove Advertisements
