Rear shocks all the way up
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear shocks all the way up in Cadillac Escalade Forums; I have a 2006 escalade. The rear shocks are extended all the way up and will not lower and level ...
    jphearn is offline Cadillac Owners Member
    Feb 2013
    4
    I have a 2006 escalade. The rear shocks are extended all the way up and will not lower and level off.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: Rear shocks all the way up
    jphearn,
    Unfortunately, Katie and I as customer service agents don't have many technical resources to help troubleshoot in situations like these. Let us know if you decide to work with a dealership to get this resolved as we're available to work with you through that process.
    Sarah (Assisting Katie), Cadillac Customer Service
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jphearn
    Check the rear lift/dive sensors as they work the rear shocks sounds like they are loose
    SugsPa is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade, 2008 STS-V
    Jun 2013
    Paducah, KY
    61
    40
    jphearn, Were the rear lift/dive sensors the problem. I just replaced my front and rear with Monroe shocks and WOW, what a difference the ride is. They needed replacing badly; however, I now have the same problem as you. The rear shocks will not deflate, they stay tight as a tick all the time. I haven't heard the pump kick on but once when it filled the shocks with air that was it. Been about two weeks since I replaced them and they are still tight with air and it looks jacked up in the rear. I read through 9 pages of posts and only two or three had this problem but none posted a fix. Thanks,
    SugsPa
    Huddy's Avatar
    Huddy is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade ESV
    Feb 2015
    180
    The compressor should make a puffing noise letting air out after the truck is turned off. Mine usually does it after my family of 5 exits the truck, as the system re-levels. Maybe the exhaust solenoid on your compressor is not working? Did you replace the compressor when you replaced the shocks?
    Mar 2011
    speedwell tn,
    11,884
    ^ hit the nail on the head
    Jun 2013
    Paducah, KY
    61
    40
    No, I didn't replace the compressor but it is less than a year old. Is there a fix for the exhaust selonoid or do I need to replace the compressor again? Thanks, SugsPa
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by SugsPa
    If you got it from gm they may have a warranty on it(my dealer does on parts)
    If not there is a member on here who can repair the compressor so it works again
    godsdiablo's Avatar
    godsdiablo is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac Escalade
    May 2008
    New York
    1,177
    How much to fix the exhaust solenoid
    Silver04 is offline Cadillac Owners Fanatic
    Automobile(s): 04 ESV
    Jan 2009
    Minnesota
    201
    I "fixed" my first one a while ago. I removed the solenoid from the compressor and had to re-solder one of the fine copper wires which had broken away. It worked for a while...before it broke again!
    N9LO's Avatar
    N9LO is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 Escalade 6.0
    Jul 2014
    Central Wisconsin
    62
    573
    I had my rear shocks and compressor replaced last week. I saw that the rear was noticeably higher than it was with blown shocks and compressor which looked level. I thought i might have the same problem as you. I never heard it run on start-up or release on shut down. Today I went back to my mechanics shop and opened the drivers window and got out and closed the door with the motor running. I reached through the window and turned off the key and jumped to the rear tire. There it was, PSSHHHHHHT. It was working. On the way home I looked a a lot front and rear wheel wells of Yukons, Tahoes, and a few Escalades. They were all noticeably higher in the rear.
    Mar 2011
    speedwell tn,
    11,884
    The factory shocks will create a "raked" effect when level
    Now if they are pumped up full then there is something wrong
    N9LO's Avatar
    Jul 2014
    Central Wisconsin
    62
    573
    Quote Originally Posted by the cadillac man View Post
    ECHO, I already wrote, "On the way home I looked at a lot front and rear wheel wells of Yukons, Tahoes, and a few Escalades. They were all noticeably higher in the rear."
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by N9LO
    I was saying if they was higher then that then something isn't right
  17. #15
    Jun 2013
    Paducah, KY
    61
    40
    the cadillac man,
    I ordered another one from RockAuto. PM me the person who works on them and I'll send him one he can have.
    Thanks,
    SugsPa
  18. Remove Advertisements
