Driver side washer fluid....EXT
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Driver side washer fluid....EXT in Cadillac Escalade Forums; Seems like my driver side washer fluid runs out first once I start getting low??? I have a 2002 EXT, ...
    Pitbull14218 is offline Cadillac Owners Fanatic
    Automobile(s): 2002 White Diamond EXT
    May 2012
    124
    Seems like my driver side washer fluid runs out first once I start getting low??? I have a 2002 EXT, anyone having his problem?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Pitbull14218
    Could be clogged on the spray nozzle as they should both work at the same pressure
    May 2012
    124
    Re: Driver side washer fluid....EXT
    Yeah idk I think when it gets low it only comes out passenger side. Ill have to fill it to see if the drivers side will work after I fill it
    Mar 2011
    speedwell tn,
    11,884
    If that don't do any good then the pump may be getting worn out
    May 2012
    124
    Yeah it didn't squirt out the drivers
    Mar 2011
    speedwell tn,
    11,884
    Check the hose coupler for the front washer the drivers side may have came loose or off
    May 2012
    124
    So the next day they both worked, seems intermittent. Is there two pumps, one for each squirter? Maybe one is going bad?
    Also this winter I went through almost 4 gallons of washer fluid, I didn't see a leak but it seems like a lot to use for the winter.
    Mar 2011
    speedwell tn,
    11,884
    There is only one pump for the front and one for the rear most likely it is a hose issue
  11. Remove Advertisements
