Gas gauge has gone whacko
Results 1 to 12 of 12
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Gas gauge has gone whacko in Cadillac Escalade Forums; I filled up yesterday...drove home and parked. I went out this AM and started up ready to drive to work. ...
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Aug 2012
    West Palm Beach, Fl
    234
    I filled up yesterday...drove home and parked. I went out this AM and started up ready to drive to work. I noticed the fuel gauge was reading way past full and it stayed that way most of the day. Finally on the way home it had moved to the Full mark...but I know I used 1/4 tank.
    I notice also that when I turn off the switch the gauge drops to 1/2 tank instead of empty.
    What has suddenly happened? Any ideas?
    jjtwomey's Avatar
    jjtwomey is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade 500XS
    Nov 2012
    Massachusetts
    58
    Quote Originally Posted by sprink60 View Post
    It may be too obvious, but did you tap on the gauges... Sometimes the needle gets stuck and won't read correctly
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    Re: Gas gauge has gone whacko
    Quote Originally Posted by jjtwomey View Post
    why not...i'll try it!!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Sprink the stepper motor may be going bad
    My moms 02 does this on the oil pressure gauge
    If the tapping on the face don't work try cycling the key a few times
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    913
    Check on your local craigslist for "GM clutser repair". I know in a couple of different cities that a rtepair man will come to you to do the swap out. for a fair price.
    Or its a pretty easy DIY (and cheap) if you can solder.
    Check on your local craigslist for "GM clutser repair". I know in a couple of different cities that a rtepair man will come to you to do the swap out, for a fair price.
    sprink60's Avatar
    Aug 2012
    West Palm Beach, Fl
    234
    OK...weirdness continues...now the gauge works normally. Go figure. I read up on the step motor phenomenon..thanks for the info. I guess mine is giving me a heads up that someday sooner or later the gauge cluster will go out.
    Feb 2010
    913
    Thats how they "go". Sometimes they work then poof it goes crazy then returns to normal.
    Save yourself the headache and either way you decide to replace them do them all at once. I did the gas gauge first, a month or so later the tach started acting up, I replaced the tach then the speedo started thats when I said heck with it and replaced all the rest.
    Ebay is your friend on these parts.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jnrsesv
    I agree once one starts then they all do it
    '49 Ford Coupe is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    Jun 2012
    36
    here ya go...I just ordered 7 steppers plus all the lights.. going to do it this afternoon...
    http://gm-stepper-motors.weebly.com/
    and how to do it
    this is the best that I've found on youtube
    http://www.youtube.com/watch?v=2u51-HTpweI
    and part 2
    http://www.youtube.com/watch?v=7FIzqZYgHBw
    Good Luck
    Ooh I nearly forgot...
    you should also replace the bulbs.. here's how to do it
    http://www.youtube.com/watch?v=fC_dE0iZtxE
    Jun 2012
    36
    Just finished the install/upgrade. I had three lights out on the dash that I never noticed. They are a BEAR to get properly soldered on the board. It's a "surface solder", and there's hardly any available area to solder them. I replaced all the steppers too. It's best to take the thing back to the truck and plug it in, start it, and check all the lights and gauges before you button everything up. I DID put the front plastic on though to avoid screwing up the gauge needles.
    Feb 2010
    913
    Hmm I haven't had any of the dash lights burn out yet.
    But good advise as far as plugging the cluster in and checking for burned out bulbs before putting all back together.
    Jun 2012
    36
    The thing is, I had no idea that any were burned out until I plugged it back in without the gauge cover on it. There seems to be enough light bouncing around in there that if you loose one, two, or three (in my case) if they aren't right next to each other it's hardly noticeable.
  15. Remove Advertisements
