one monroe rear and one factory rear shock
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, one monroe rear and one factory rear shock in Cadillac Escalade Forums; Well, after having the codes pulled, I discovered that one of the "used" monroe 40032 is throwing code C0585 - ...
    90limited is offline Cadillac Owners Fanatic
    Automobile(s): 2003 EXT / 1976 Eldorado
    Aug 2012
    178
    Well, after having the codes pulled, I discovered that one of the "used" monroe 40032 is throwing code C0585 - left rear actuator . This is what is causing the SRC to pop up. Only one of my factory shocks was leaking. Am I asking for a headache to leave the one good monroe in and put the good factory back in? I am pretty sure that I will not go this route. Just thought I would see what the forum says...
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by 90limited
    It wouldn't hurt to do that till you can get a replacement Monroe shock(its better then the src message(and less annoying)
