OEM fog light lens glass or plastic?
Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, OEM fog light lens glass or plastic? in Cadillac Escalade Forums; I'm trying to buy replacement fog lights for my escalade and were wondering if the oem fog light lenses are ...
    Tx_Lee is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Escalade (sold)
    Mar 2010
    Houston, TX
    30
    92
    I'm trying to buy replacement fog lights for my escalade and were wondering if the oem fog light lenses are glass or plastic? found a good deal on ebay http://www.ebay.com/itm/330786672347...84.m1423.l2649 and wanted to make sure they will look and function as much as the OEM as possible.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Tx_Lee
    I got a set on amazon for 50 bucks brand new with bulbs and they work great FYI make sure you aim them after installing them
    Also the lens on both the headlights and fog lights are plastic(even the taillights have plastic lens) there hasn't been a glass headlight since the 70's not sure on the fog lights as far as oem goes but I'd say its the same except aftermarket fog lights)
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    Re: OEM fog light lens glass or plastic?
    what happend to your originals? Reason i ask is because when I bought my Escalade the lights were there but the lens were straight up missing! I ended up getting a set of "capa certified" ones on Rockauto.com for $50 a peice, and they work great other than the fact one of them had traces of water inside it after a car wash. just a quick bead of clear silicone fixed it. I think originals from Cadillac are somewhere in the range of $70..
    Mar 2010
    Houston, TX
    30
    92
    I still have the housings on the truck. The lenses have been missing for some time and everything inside the housing is black from dirt and exposure, so I think it would be easiest to get whole new housings and replace altogether.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by YoshiMan
    Try over 100 for one close to 300 for both I got both on amazon for 50 with free shipping and haven't had a problem with water except for a one time at the car wash due to dirt between the bulb and housing
    That is how my mom's 02 is odd thing was that one still had the lens but it had a bead of silicone on but it fell off one day when I started the truck
    both lens were m.i. a. on my 03 when I got it I tried aftermarket housings (worst mistake ever) they sucked so I looked online and found my set at amazon and I will do the same for my moms 02(I wish gm had the hid low beams on the 02 but that can be a project of mine sometime after I do the air box improvement for the air shock compressor)
    Caddy2004X is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade EXT
    Jan 2013
    24
    Got mine from eBay, they are plastic, cost me 27 bucks free shipping with the braket. I did remove the plastic retainers and put in a screw with a bolt, nice and tight, next are the H.I.D.s. Seller: carpartswholesale, easy and fast as heck.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Caddy2004X
    Stick with the 4300k color as it gives the most light
    Mar 2010
    Houston, TX
    30
    92
    does 4300k best match the original HID low beams?
    Mark Edward Morrison's Avatar
    Mark Edward Morrison is offline Cadillac Owners Fanatic
    Jun 2012
    419
    Cadillac Man is correct 4300K is the brightest temperature of LED's. I have 6000K LED's in mine and they match the factory HID's almost perfect. If you do a lot of driving on dark roads and such get the 4300K LED's but if you want it to match and are just looking for that, go with the 6000K. I turn mine on at night to match my HID's just for looks. I have never been brighted by other drivers or pulled over for having them on. For me it is just esthetics.
    Mar 2011
    speedwell tn,
    11,884
    Yes they do
    Jun 2012
    419
    Tx_Lee, google HID colors and 4300K, and you will see it does NOT match the factory HID's what so ever in my opinion. If you need it for lighting like Cadillac Man says by All means get the 4300K! If you want it to match and don't drive on super dark roads etc go with 6000K. I have 6000k fog LED's and will send you a picture to show you they match... 4300K looks like a halogen bulb in my opinion, they are brighter but like I said I matched mine for looks not for brightness. PM me and I will gladly send you a pic of mine on with my low beam HID's and you be the judge.....
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Mark Edward Morrison
    The guides online at the hid sites are misleading as the oem bulbs are 4300k they trick you into getting 6000k bulbs as they show it being a white color when in fact it is a bluer color then oem which is 4300k and has a slight yellow tint to the beam
    I know as I bought two hid kits with 6000k bulbs where the seller said they was white(they aren't)
    The only seller I get my bulbs and hid kits from is here www.kensun.com buy a set of 4300k bulbs from here and you will get true 4300k bulbs same with 6000k bulbs
    I also know that factory hids are legal with 4300k bulbs any other is considered illegal by federal law
    Also mark take a close look at the lumens ratings of both 4300k and 6000k bulbs and you will see that the 4300k bulbs have more lumens=better lighting(FYI 4300k bulbs color shift up to closer to 5000k as they age)
    There is a forum that has a guide to hid bulbs and the colors along with the lumens ratings are listed
    6000k has 1300 lumens 4300k has 3200 lumens
    Aviator2005 is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV Platinum
    Jan 2013
    8
    I bought a set of fog lights from grill4you about two weeks ago. They were not the right fit. The mount is different and the struts going from the mount to the light is about half an inch too long. All in all the light will mount about an inch lower than the original. I will try to attach a picture for illustration, but this is my first post and it may come out as intended.
    The customer service guy at grill4you, Justin, was very apologetic and helpful in the resolution of this issue, but in the end I had to go to another vendor for replacements. They are very easy to take out (3 screws). When I get some more time, I will put together a "how to" post as it seems to be a common problem.
    Mark
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Aviator2005
    Mark
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=103782"/>
    They look like Chevy fog lights I got my set from amazion
    Here is the link
    http://www.amazon.com/gp/aw/d/B002PQ...motive&sr=1-62
    These are a great replacement set and include bulbs but I suggest getting a hid kit from here
    www.kensun.com the socket size is 880 the color that gives the most light is 4300k
  17. #15
    jnrsesv is online now Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum, 250,000 still looking fine, really fine!
    Feb 2010
    Sunny South Carolina
    934
    Here is ours with the Kensun 4300k, I would say its a very close match to the HIDs.
  18. Remove Advertisements
