Steering Wheel Control Switches/Bulb Replacement W/Pics - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 51
Like Tree2Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Steering Wheel Control Switches/Bulb Replacement W/Pics in Cadillac Escalade Forums; They have to be desoldered, but the good news is you only have to touch the backside of the circuit ...
  1. #16
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    916
    Re: Steering Wheel Control Switches/Bulb Replacement W/Pics
    They have to be desoldered, but the good news is you only have to touch the backside of the circuit board for a quick second with the solder gun and I used my thumb to "release" the bulb. Its a very easy and quick process per bulb.
  2. #17
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    groovy, I'll add this to my list of things to do. seems pointless to replace the whole switch for just a bulb even if they are relatively inexpensive
  3. #18
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by YoshiMan
    Just make sure you let the truck sit with the battery disconnected for at least 45mins before you remove the air bag unless you want a broke nose
  5. #19
    60COUPE is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade, 1989 Fleetwood
    Jun 2011
    5
    Im a pro tech I did not unplug the air bags just tiped it out of the way and used Dorman assy's from Rock Auto (my were rubed off) around $15. each. I know you don't mess around with air bags and I don't but we have NEVER had one blow off. Good Luck
  6. #20
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by 60COUPE
    Never say never as you don't know when it can happen
  7. #21
    siccs502 is offline Cadillac Owners Member
    Automobile(s): none
    Feb 2013
    none
    13
    Quote Originally Posted by the cadillac man View Post
    They have to be desoldered as the only bulbs that disconnect and pop out are the ones for the analog clock in the center(which btw is a pain to find)
    Can you get just a new switch with the bulbs in it so you dont have to solder?
  8. #22
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by siccs502
    Yes but it depends on your budget(plus LEDs last longer and run cooler then standard bulbs)
  9. #23
    Feb 2010
    916
    Yes the bulbs are in the new switch.
  10. #24
    starnold is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade Gold Edition
    Jan 2013
    12
    Great write up!! Thanks a ton for taking the time to post this for those of us with this problem!! Awesome pictures! Very helpful.
  11. #25
    LongRX7 is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade Diamond White - 2011 CTS4 Prem Diamond White
    Jul 2003
    Yukon, OK
    46
    95
    Thanks for the write-up. Will be helpful for me.
  12. #26
    djais1801's Avatar
    djais1801 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 EXT Sable Black
    Feb 2011
    NJ
    47
    246
    Thanks again for the great write up...I had mine replaced with switches off ebay..just needed 3 out of 4 done. my local cadillac tech did them on the side for me. had to take the wheel off and airbag out, because there wasn't enough slack in the wiring for one of them. no waiting 45 min w/ battery unhooked, etc. just cleared the airbag code when reinstalled.
  13. #27
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by djais1801
    He knower what he was doing that's why he didn't unhook the battery but it is recommended if you do it yourself as static discharge can cause the air bag to deploy
  14. #28
    Silent_Assasin's Avatar
    Silent_Assasin is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade EXT - Rip Tide Blue
    Mar 2013
    30
    200
    Seems like ALOT of work when you can just buy all new switches for 100 bucks, pull the old ones out, pop the new ones in, BAM! Easy enough! .... Excellent job on the post though! pictures couldn't be better!
  15. #29
    NorthstarSTS06 is offline Cadillac Owners Member
    Automobile(s): STS
    Aug 2009
    53
    4
    Great info. So glad that Cadillac saved so much money on these cheap bulbs. I have 3 to replace on my steering wheel and four others in the other switches.
  16. #30
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by NorthstarSTS06
    Its a gm cost cutting move that got done on all models
    Darn penny pinchers
  17. Remove Advertisements
