2000 Escalade Headlights Not Working at all
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2000 Escalade Headlights Not Working at all in Cadillac Escalade Forums; No low beams or high beams. The manual switch didnt turn them on, and I haave replaced the switch control, ...
    connestoga is offline Cadillac Owners Member
    Automobile(s): 2000 Escalade
    Jan 2013
    6
    No low beams or high beams. The manual switch didnt turn them on, and I haave replaced the switch control, but no luck. I also replaced the BCM, still no luck. THE parking lights come on with no problems. Also, the parking brake itself is NOT engaged, but It's the first thing I thought that might still be causing a problem. I have read several posts on here about Daytime running lights and possible sun load sensor problems, but since I can't even turn the lights on manually, I don't know if that is the problem or not. I have checked all the fuses pertaining to lights, so I now need someone to give me more ideas. THANKS GUYS FOR HELPING THIS OLD GAL OUT!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by connestoga
    Not sure on the fuses but it sounds like the bulb fuses are blown(if the bulbs aren't bad) try different bulbs and see if the headlights work
    Jan 2013
    6
    Re: 2000 Escalade Headlights Not Working at all
    Sorry to be so ignorant, but when you say bulb fuses, are these specific fuses in the panel? I might have missed them. I will do as you suggested though and buy a new bulb to try. I just wonder what the chances are of both going bad at the same time and/or if one goes bad, does the other one quit working? THANKS FOR YOUR HELP!!! Gives me something else to try.
    Mar 2011
    speedwell tn,
    11,884
    It might be possible but the bulb fuses are in the underhood fuse box
    Jan 2013
    6
    THANKS! I'll take a look again to see if I can find those fuses.
    Jan 2013
    6
    I looked for bulb fuses in the underhood fuse panel, and did not find them. I wanted to check these before buying bulbs, BUT the good news is, my DRLs are now working. I still can't turn the headlights on manually (and they still don't work automatically). Another thing I noticed is, if I click to turn the high beams on, not only do they NOT work, but the indicator light for them on the instrument panel no longer illuminates. My truck has a big brushguard, so getting to the lights to swap bulbs will take some doing and i am saving that task for tomorrow. ALSO...is there a headlight relay I can check too? I didn't see this relay in either fuse panel and wondered where its located. Like you suggested before, its likely a bulb problem, but I can't figure out why the DRLs now work and didn't work before. The only thing I did again today was, I pulled the 50 amp headlight fuse out and plugged it back in. I had done this before when I checked it a couple of days ago, so I sorta doubt that helped anything. Maybe driving it down the road helped reset the computer after the BCM was installed? I just don't know. I plan to read all I can about the headlight bulbs and differences between the DRL, low beam and high beams. thanks for any advice!!!
    Mar 2011
    speedwell tn,
    11,884
    Try checking the relays as they can fail but one thing before you do(to make sure the switch is working)is the running lights working?(running lights are the on when the headlight switch is in the p position) if they don't then it could be a relay or switch issue if they do and the head lights don't work then it may be in the switch(I had this happen on a 02 (it had outside lights but no dash lights)
    Jan 2013
    6
    Thanks. I'll pull the switch. Can you tell where the headlight relay is? Another thread mentioned under the dash beside radio???
    Mar 2011
    speedwell tn,
    11,884
    Not sure I know on my 03 they are both in the under hood fuse box check there some may have them in the dash fuse box
    Jan 2013
    6
    The switch ckecks Ok and when in the headlights on or parking lights positions, I hear the chimes after I remove the key.
    The bulbs are also ok. I've downloaded a shop manual for the Escalade and while it's been very useful, there's still some things about the 2000 year model that I can't find enough info about - whether or not there's a separate relay for the headlights Or if it's only called a DRL relay is one thing that has me baffled. I think this DRL relay is the one that's suppose to be beside the radio, so I'm stll trying to find if there is in fact another headlight relay. Also, you mentioned the 2003 and looking at the fuse panel diagrams for years later than the 2000 look totally different. I think the last year model the manual covers is 2006, so I guess some things were fairly standard through these year models, but man....when they're different they're totally different! The dash end fuse panel on the 2000 has about the same number of fuses as later years, but the underhood panel on the 2000 doesnt have near as many fuses and relays as later models. I would much rather have more and all in one place so they would be easier to find! ANYWAY...THANK YOU AGAIN FOR HELPING ME!
    Mar 2011
    speedwell tn,
    11,884
    I am glad to help but I guess in order to find the relay location you may have to go to a local dealer and ask the service manager where it is at since I have service manuals for the 02 and up to 06
    Bjcomm96 is offline Cadillac Owners Member
    Mar 2012
    50
    1
    Did you ever figure this out? I'm having the exact same issue. My DRL's work but no headlights high or low. I'm stumped
    Brian
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Bjcomm96
    Brian
    Check your multi function stalk
  16. #14
    Kornfed is offline Cadillac Owners Member
    Automobile(s): 2000 escalade
    Dec 2015
    39
    3
    Hey Cadillac Man I have the same problem with no headlights or hi beams. Can you help me with this please?
  17. #15
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Kornfed
    Have you checked the basics like the fuses and relays?(always check those first)
    Does the running lights work(first notch on the switch)
    I do know the multi function stalk works the low beams and high beams just want to make sure on the other stuff first
  18. Remove Advertisements
