blend door actuator ?????
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, blend door actuator ????? in Cadillac Escalade Forums; On my esv my heat only works on 90, 89 and it will come out cold. Same when ac is ...
    chacho44 is offline Cadillac Owners Member
    Automobile(s): escalade esv
    Dec 2011
    80
    On my esv my heat only works on 90, 89 and it will come out cold. Same when ac is on its the same from 60-89, I like the 70-72 mark but its basically the ac. Idk what this is or where to start off with. Basically during winter time either I have it on 90 at all timecause 89 is pretty much ac, and summer i can have it on 60 even though I can put it on 89 and it will still be ac cold. I found some info from here something about a air mix blend actuator. Since there are a more than one I wanna mame sure I get it right the first time. Thanks
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by chacho44
    The actuator for the drivers side temp door(if it just does it on the drivers side) is on the bottom of the dash on the passenger side you will need to remove three screws(one is a pita to get to so I suggest leaving it out its at the tranny hump)
    then remove the panel and you will see the actuator for the drivers side temp door remove the two screws(do NOT have the key on at this time or you can damage the actuator)and the actuator works out with little fuss(I had the opposite in the summer with the heat going full blast on the driver yet ice cold on the passenger I had to take the actuator apart and clean the position contacts haven't had a problem since.
    Dec 2011
    80
    Re: blend door actuator ?????
    I never paid attention ill have to check if its both sides
    Dec 2011
    80
    Ok it does the same on both sides, 90 is hot, 89 is cold.I kept the drivers side on 90, passenger side at 72 and it was cold. Even at 89it was cold, some ppl tell me its the controls and I need to replace it. Advise please
    Mar 2011
    speedwell tn,
    11,884
    That's what it sounds like I suggest having the tech-2 connected to the truck to see for sure.
    Dec 2011
    80
    Ok I borrowed a friends air controls from his 04 Z71 Tahoe, and my truck soes the same thing even with his contols and hos truck operates fine. I'm clueless guys, I mean I'm used to having the truck on 90 now but after a while of driving it kinda sucks. Literally feels like me heats on cremation lol.
    Mar 2011
    speedwell tn,
    11,884
    Temp door stuck and/or failed unless it is a sensor
    Try this turn the blower all the way down and work the temp controls
    FYI three screws and you can remove the kick panel under the right side of the dash(7mm socket) and you have access to the drivers side actuator
    If the actuator moves then its good if it don't then its bad
    Unless its a sensor(which are buried in the dash but one is accessible behind the radio) still would need a tech-2 to be sure but I think it still would let you control the temp door(again not sure)
    Dec 2011
    80
    Thanks Cadillac man, ill give it a try. Also what do these sensors look like, and how can a tech two possibly figure it out if its not throwing a code.
    Mar 2011
    speedwell tn,
    11,884
    You can tell each component what to do with the tech 2(eg turning on the air shock compressor at the touch of a button) plus it gives the readouts of the temp sensors for the hvac system
    There is a in car temp sensor(in the headliner above the drivers seat)and a air duct sensor for each side in the front and in the heat duct for each side
    The rear system is almost identical to the front but for a single zone and has the same style sensors
    FYI I have a service manual that covers both systems if you want I can email them to you
  12. Remove Advertisements
