parking sensors
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, parking sensors in Cadillac Escalade Forums; a few days ago my parking sensor stopped working. only the red light is flashing but the yellow and orange ...
    gerschouten is offline Cadillac Owners Member
    Automobile(s): Escalade 2003
    Oct 2012
    24
    5
    parking sensors
    only the red light is flashing but the yellow and orange don`t.
    also the 'beeps' arrent there...
    can someone please help me.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by gerschouten
    That means there is a code in the system you can check yourself by jumping the harness which is located near the unit under the second row passenger side seat
    Take a paper clip jump the harness then turn the key to run(engine not running) and shift into reverse while watching the lights it will flash the outside red and yellow lights at the start and finish of the code readout
    Let me know what the codes are.
    Oct 2012
    24
    5
    Re: parking sensors
    sorry my english is not that good...
    the harness is the little black box? wich is located under the seccond row passenger seat.
    and what should i do with it, i diddnt understand.
    i pulled the plugs and put them back in for a lil` reset, but that diddn't work...
    so please tell me what to do,
    thanks.
    Ger Schouten.
    Mar 2011
    speedwell tn,
    11,884
    thanks.
    Ger Schouten.
    There is two harnesses the test harness is taped up with the wiring bundle about a few inches from the module no need of unplugging the harnesses from the module(which is located under the second row passenger seat)that plug into the module(little black box under the seat)
    Oct 2012
    24
    5
    Re: parking sensors
    and what should i do with the harness?
    the harness is the taped up thing with the cables you say?.
    because I have only one black box untherneeth the seat
    Mar 2011
    speedwell tn,
    11,884
    You have to look close as the test harness is black and small
    scottf is offline Cadillac Owners Member
    Automobile(s): None
    Dec 2012
    7
    Re: parking sensors
    Is this module and connection actually under the second row rear passenger seat? According to the pictures from Mitchell on Demand, it says its along the left rear wall under the window (behind trim panel). If someone could take a picture of where this module is really at I would appreciate it!
    Thanks,
    Scott
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by scottf
    Thanks,
    Scott
    The base model and ext it is under the right rear seat it has Bosch on the label
    Automobile(s): None
    Dec 2012
    7
    Re: parking sensors
    Thanks.. And Right rear meaning right at the back? Or the seats just behind the front seats?
    Mar 2011
    speedwell tn,
    11,884
    Second row seats
  13. Remove Advertisements
