condensation in fog light
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, condensation in fog light in Cadillac Escalade Forums; I noticed lately that my passenger side fog light has condensation and a bit of water in it What can ...
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    What can cause this?
    I had the truck washed today before I went to pick up my replacement DVD player and didn't notice it till I got home and seen it I thought it might have got in there at the wash
    I removed the bulb (which is a hid) to make sure there was no water on it before I turned them on to let the bulb heat the housing up In hopes of it drying out the housing but no luck
    I am going to see if the warranty is good to see if I can get a replacement if not I will just buy a new one
    rfishoutofwater is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade EVS Platinum Rip Tide Blue
    Jul 2012
    44
    164
    Not uncommon. I had to replace both of mine due to the lens coming apart from the housing. I paid like 60 for a pair.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by rfishoutofwater
    Is this caused by my hid bulbs or not(I doubt it though as both would be doing it)
    Jul 2012
    44
    164
    No more than likely the seal on the cover is failing allowing moisture in. Eventually it can fill with water and blow a bulb.
    Black88GTA is offline Cadillac Owners Fanatic
    Automobile(s): 03 Escalade AWD 6.0L
    Jul 2012
    36
    107
    Re: condensation in fog light
    Before replacing it, I'd try removing it, taking out the bulb, and drying it out with a hairdryer. Then put a bead of silicone around where the lens is bonded to the housing.
    Mar 2011
    speedwell tn,
    11,884
    Not good considering how these hid bulbs shatter
    Quote Originally Posted by Black88GTA
    Ok I will try that as soon as the rain lets up
    It didn't seem to be coming from the lens area but the bulb area but I will take the extra precaution and put some silicone around the lens
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    907
    Quote Originally Posted by Black88GTA View Post
    Thats what I did, hell of alot better than spending $$ on replacement fog lamp assemblies.
    *NOTE* Use clear silicone to adhere lens to fog lamp housing. I had some black RTV laying around the first time, and it kinda gooed into the housing. I had to remove the lens and reseal with clear silicone and looks just like new.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jnrsesv
    Ok I will try to remove the housing and do that tomorrow.
    spirit man's Avatar
    spirit man is offline Cadillac Owners Member
    Feb 2013
    44
    QuestionRe: condensation in fog light
    Quote Originally Posted by the cadillac man View Post
    Did you give this a try? I got a brand spanking new pair of TYC fog lights. After the first rain they were in, there was mad condensation on the inside. I would hate to go through the hassle of buying another pair when I could get this resolved. I too have 880 HID bulbs as well. Should I just run some clear silicone on the outside or do i need to take the fog lights off and run some water in it to check for leakage?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by spirit man
    I ended up not needing to as there was dirt on the bulb base I cleaned it and haven't had this happen since
    spirit man's Avatar
    Feb 2013
    44
    Well shoot...I'll have to play with mine after work.
  14. Remove Advertisements
