Suspension issue
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Suspension issue in Cadillac Escalade Forums; Was driving my wifes escalade yesterday for the first time in a while. I think i recall when you start ...
    vicb is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade, 2002 SL 500 Silver Arrow
    Jan 2012
    Plano, Texas
    49
    141
    Suspension issue
    Was driving my wifes escalade yesterday for the first time in a while. I think i recall when you start it, it would make a noise in the back from the air suspension getting ready. When i started yesterday i heard no noise from the suspension at start up, but i am not getting any error messages.
    when you start the escalade, does the suspension make noise as if it is filling with air, or do we have an issue?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by vicb
    Try this turn the key on with the engine off and see if you hear the compressor if not then something isn't normal and you should be getting the service ride control message(and a code would be in the system that the tech-2 can read)
    Jan 2012
    Plano, Texas
    49
    141
    Re: Suspension issue
    Did as you suggested. No noise from compressor and no service ride control message. About 6 months ago we had new tires put on..could that have caused an issue?
    Mar 2011
    speedwell tn,
    11,884
    It depends on if they used a lift but I doubt it really causing the issue.
    What year is the truck?
    Maybe the compressor motor has failed from age.
    Jan 2012
    Plano, Texas
    49
    141
    2005..Have about 80,000 miles on it.
    Mar 2011
    speedwell tn,
    11,884
    Something seems odd have you checked the fuses?
    There is a relay for this next the fuse box under the hood
    TLMC is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade 1969 ss396 chevelle 1967 GTO
    Nov 2011
    BOYNTON BEACH,FL
    62
    76
    The only way the compressor would run every time you started the truck would be if you had a leak in the system. If there is no leak the compressor will not run on start up.
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by TLMC View Post
    I don't mean to thread jack, but I've read this quote several times from several different members and I have a related question. I have noticed that when I shut my Escalade off and get out I can hear the air pressure from the rear end release. It is usually about 1 minute after getting out and it is a distinctive rush of air, not a leak. Naturally since the air pressure releases when i get out, the compressor must run and fill the bags up again when i start it. I have always assumed this was supposed to happen. Does anyone have any thoughts on this?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by mikedyk43
    I am thinking the shocks has a leak that is sealed when a certain amount of wight is in the truck
    This how I checked mine get some soapy water in a spray bottle and spray the shocks fully where the bladders are then start the truck (while sitting in it) wait till the air compressor shuts off wait a few minutes,
    then get out and watch and wait till you hear the air noise and see if there is bubbles if there is any there there is a leak and the shocks need replacing(mine blew out at night I inspected the shocks but till I soaked them with the soapy water I didn't find the leak) I hope I have helped
    mikedyk43's Avatar
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by the cadillac man View Post
    I thought about that, however if that were case, the pressure would release immediately after exiting the vehicle. It just seems too controlled for it to not be intentional. It sounds like a valve opens and lets the air out.
    Mar 2011
    speedwell tn,
    11,884
    It depends on where the leak is at but if it is a valve then the module may be the culprit(this is next to the rear air system) the best way may be to probe the system and see what's up
    Jan 2012
    Plano, Texas
    49
    141
    I could have sworn in the past at start up the compressor would make noise. So you are saying that isn't the case and I have no problem?
    Nov 2011
    BOYNTON BEACH,FL
    62
    76
    You have no problem
  16. #14
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,802
    I would say Perfectly normal mine does the same, also my compressor pumps up every time because it dumps the air a few minutes after i turn off the vehicle i have the long wheel base so probably more activity then the short wheel base due to more weight over the rear wheels
  17. #15
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wesyder
    That isn't how the compressor does on my dads h2 as you can hear the valve clicking as it levels out the rear(even after the truck is off)
  18. Remove Advertisements
