Air Ride Questions
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Air Ride Questions in Cadillac Escalade Forums; Hello Everyone, I just purchased a used 2005 Escalade AWD and have a question with the air system. When I ...
    chrisnlbc is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Oct 2012
    11
    Air Ride Questions
    Hello Everyone,
    I just purchased a used 2005 Escalade AWD and have a question with the air system. When I am towing my travel trailer, I noticed yesterday when I pulled over from after driving an hour or so that the back had lost all air. My chains were dragging etc.
    When I turn on the truck, you can hear the compressor going, and it pumps up fine the stops once it reaches level height.
    My question....obviously its supposed to pump and compensate the whole time driving. What is going bad? Compressor or Shocks? Also it loses air while its parked overnight? Are the shocks supposed to leak down while sitting?
    I want to take it back to the selling dealer because obviously something isnt right.
    Thanks!
    Chris
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by chrisnlbc
    Hello Everyone,
    Thanks!
    Chris
    You will need to replace your shocks as they are leaking due to age and wear plus if you don't replace them soon you will need to replace the compressor as well as it will burn it up by trying to keep the truck level
    '49 Ford Coupe is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    Jun 2012
    36
    Re: Air Ride Questions
    Well, here is my two cents. There is probably a leak in a fitting/tubing/and/or shocks. The valves in the compressor may be leaking back, and there may be no leaks at all external to the compressor. It's a pain in the butt, but get under the truck and load up a spray jug with soapy water and spray it everywhere related to the system. You may have to pull out the compressor/bracket assy behind the drivers side rear wheel. Three bolts, you don't have to take the bolts all the way out, just loosen them and lift it up and slide it out. See my posts on other threads about what's going on with the ride system. If you need a compressor, get the Arnot out of Florida.
    Oct 2012
    11
    Thanks Guys. I will do the spray jug test. Today I just drove the truck and the "Service Ride Control" alert came on the the panel. Does that mean something finally went bad?
    Mar 2011
    speedwell tn,
    11,884
    Get the codes pulled most likely the exhaust valve solenoid had failed meaning the compressor will need replacing(unless its is a sensor)
    Jun 2012
    36
    To be more precise, the exhaust solenoid is the one single source of the most common failures in this system. Not only did the GM engineers f' up in placing the compressor in the worst possible location for water contamination, but the solenoid which is attached to the compressor IS NOT water proof. Hence, early failure. Caddy parts dept wants 500 bucks for a compressor, cause they DO NOT sell the solenoid by itself. GET the Arnott compressor, which has a dryer rebuild kit, fix it yourself for about 200 bucks...
    Oct 2012
    11
    Quote Originally Posted by the cadillac man View Post
    Thanks, whats a cheap scan tool I can buy? What type do i need?
    Chris
    I will do that , thanks for the info!
    Quote Originally Posted by '49 Ford Coupe View Post
    Thanks 49 I appreciate your advice.
    Jun 2012
    36
    Pull the compressor/solenoid out and ohm the solenoid. You will most likely find an open circuit. The 'puter monitors that circuit, and if it sees an open circuit, it will not tell the control relay under the hood to pull in, and shoots the error message.
    Mar 2011
    speedwell tn,
    11,884
    Chris no basic scan tool can get that code that I know of(I have one myself no dice) the only way is with the tech-2
    Oct 2012
    11
    Whats odd is that my compressor turns on when starting the truck for 10 seconds and airs up the back. Would it still do this if it had this open circuit?
    Mar 2011
    speedwell tn,
    11,884
    Nope it don't do a thing I know mine is like this.
    Jun 2012
    36
    If it airs back up, or the compressor comes on AT ALL, then the solenoid is good.... hmmmm
    Black88GTA is offline Cadillac Owners Fanatic
    Automobile(s): 03 Escalade AWD 6.0L
    Jul 2012
    36
    107
    Is it possible that the shocks / lines are leaking, but the compressor hasn't died yet? I would think that leaking shocks may cause the level sensors to never reach their cut-off point, which in turn would cause a constant run condition on the compressor until it times out. Does anyone know if the event of the compressor timing out trips the SRC message?
    In this scenario, I'd pull the harness to the compressor until I could get the shocks / lines inspected for leaks. It appears that (for now at least) the compressor may still be OK (since it runs), but allowing the compressor to constantly run like that will kill it. When I was troubleshooting my own SRC message this summer, I plugged in an Auto Enginuity tool on loan from a friend which told me that I had an open exhaust solenoid on the compressor. I never once heard my compressor running. Turned out I needed both rear shocks and a replacement compressor.
  16. #14
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Aug 2012
    West Palm Beach, Fl
    234
    I have a similar condition. I have replaced my shocks with Arnott's replacement OEM pieces and I get some lift but not what it should be. The air bags never fully inflate on my shocks so I suspect lines and compressor. My compressor runs but is noisy. I spoke to Arnott about this and they think my compressor is weak and is not creating enough pressure and is timing out...I have no codes.
    My next step is to replace the compressor, check the lines and replace them as well. The Arnott folks are great to deal with and even offered me additional discount on the compressor since I purchased the shocks from them. I am not sure if Arnott sells the lines. Has anyone here had to replace them and if so where did you purchase same?
    I haven't looked at the compressor yet to see how tough it is to replace... shouldn't be a big deal from what I have read here.
    This is a great forum...lot's of good info here and thanks to all that contribute....I would know nothing about this Air Ride system had I not read about it here.
    Stay tuned.
  17. #15
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by sprink60
    Stay tuned.
    Take some soapy water and give the lines a good soaking if no bubbles appear then the compressor is getting worn out.
  18. Remove Advertisements
