Air Ride Questions - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Air Ride Questions in Cadillac Escalade Forums; UPDATE: Took it to dealer, here is what we had happening: No Power at DLC, Inspected and found blown 15 ...
  1. #16
    chrisnlbc is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Oct 2012
    11
    Re: Air Ride Questions
    UPDATE: Took it to dealer, here is what we had happening: No Power at DLC, Inspected and found blown 15 amp fuse, Code C0625 was found. Left Rear Height Sensor rod disconnected. Reconnected and its been working fine so far. I will be pulling my trailer this weekend and we will see if it stays pumped up!
    Thanks for all the help guys.
  2. #17
    Oct 2012
    11
    UPDATE AFTER TOWING:
    Well, its still sinking After the work they did, I loaded up my trailer. took off, when I got to destination, same thing, back end on the ground. I guess they cant check it at the dealer with a load, buts its still irritating. Going to go up underneath today and spray soapy water.
  3. #18
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by chrisnlbc
    Check the lines one may be bad or has a pinhole leak in it.
  5. #19
    2MCHPWR is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade
    May 2008
    NY
    29
    i went through same exact thing: sagging rear while towing.
    sprayed water on shocks and saw bubbles so got the arnott/bilstein shocks.
    Installed them but compressor sounded weak and would sputter on/off.
    Then bought arnott compressor and swapped it on and its great now. Truck rear is pretty high.
    The stock dryer can was a bitch to open up but once opened, it was corroded inside and filled with water. The arnott compressor came with a new dryer can so that was cool.
  6. #20
    wsumiel is offline Cadillac Owners Member
    Automobile(s): 2005 escalade ext
    Nov 2012
    1
    I get a "Service Ride Control" messge everytime I start my 2005 Escalade EXT but nothing else seems to be wrong. What can cause this? Could it be a bad sensor?
    Quote Originally Posted by chrisnlbc View Post
    Thanks Guys. I will do the spray jug test. Today I just drove the truck and the "Service Ride Control" alert came on the the panel. Does that mean something finally went bad?
  7. #21
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wsumiel
    The only way to tell is have the codes pulled at the dealer with the tech-2 most likely it's the compressor.
  8. #22
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Aug 2012
    West Palm Beach, Fl
    234
    From my other thread
    "I had already installed their OEM Re Built shocks because mine were shot. I still had a rear end sag problem with my boat trailer loaded and suspected my compressor wasn't putting out enough pressure because it was worn out...I was correct. I installed the Arnott replacement compressor and drier rebuild kit and bingo...no more problem. The truck is very stable, rides like a cloud and sits level with 400 lbs of tongue weight on it. It took about 2 hours to do the job and now have Arnott's complete Air Shock/Compressor replacement package with a lifetime warranty for less than $500.
    I recommend this to those of you with rear Air Ride issues.
  9. #23
    nsx24 is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Nov 2012
    5
    So I am having the same service light and compressor NOT coming on. I did the relay jump with a wire and the compressor came on, so I then pulled off the air lines to the shocks to see if the compressor was pumping air and both sides had air being pumped. So where do I go now as I know the compressor comes on when jumped. I know it is pumping air to each shock. But not coming on with the key. HELP.
  10. #24
    Pitbull14218 is offline Cadillac Owners Fanatic
    Automobile(s): 2002 White Diamond EXT
    May 2012
    124
    Bad relay?
  11. Remove Advertisements
