Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: 2005 Escalade (ESV) Power Seat Non Functioning (Free Fix W/Pics)
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    916
    Symptom:
    Lost all power to drivers seat only. No forward/reverse, tilt or bolster/lumbar. The passenger side works normally.
    First things I checked, obvisously fuse, but alas I have looked in the manual and online, couldn't find location. I did come across a couple of circuit breakers, one under hood and one inside cab, both checked out ok. I then moved my attention to the underside of the drivers seat, what a nightmare. All visable wires looked connected and unscathed.
    Under Dash Circuit Breakers:
    I then decided to look at the Power Seat Module itself, once removed from the lower seat cushion, I found its a sealed unit. I decided to swap out with the passenger to see if the module itself failed. The working passenger side Power Seat Module did not work on the drivers side. I replaced both back to their proper places.
    Moving along, I went to the ole stand by, Google. There were many sites that recommended going to a dealer and having the module updated with new software, umm at the time I did not consider this an option. One site had mentioned to pull the 30 AMP circuit breaker for 30 seconds to reset the modules, that did not work. I continued on, many, many pages into Google, I found a site that someone posted "chaffed wires" at main power connection. Ah ha, so I contorted myself between the rear seat and drivers seat where I found the Main Power Cover, I removed it to find the power wires (no chaffed wires), I wiggled the two harnesses, and tried to move seat, BINGO loose wires at the main connection. I used small zip ties to secure the connectors together.
    Drivers side seat, now is in proper working order, forward/backwards, tilts, and bolster/lumbar
    mitch2264's Avatar
    mitch2264 is offline Cadillac Owners Member
    Automobile(s): Cadillac Escalade Platinum
    Dec 2007
    ATL
    79
    Re: 2005 Escalade (ESV) Power Seat Non Functioning (Free Fix W/Pics)
    Excellent write up!! Thank you for taking the time and energy to post this! Google can certainly be a friend--yet daunting at the same time .
    Thanks again!!
    Mitch
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    This needs to be in the FAQ section if a admin sees this please make this a sticky
  5. #4
    Feb 2010
    916
    Thanks for the thanks Mitch and your welcome.
    Hope it helps someone out someday.
  6. #5
    Oct 2012
    1
    I want to say thanks also, my seat hasn't worked for about a year now and it wasn't so bad for me cause it was stuck in my spot, however, the bad part was that the heated seat didn't work. Took me about 5 min to get it working again, that includes the time it took to read the post! Thanks
  7. #6
    Feb 2010
    916
    Phranke thanks for the thanks.
    I am glad that I was able to help you out.
  8. #7
    Mar 2014
    1
    Thank you very much!
    this is Exactly what was wrong with our truck!
    -Bob
  9. #8
    Scottparrish is offline Cadillac Owners Member
    Automobile(s): 06 escalade
    Jul 2014
    44
    1
    Thanks so much. This fixed my wifes vehicle.
    Thanks for taking the time to post this
    Quote Originally Posted by jnrsesv View Post
    Symptom:
  10. #9
    glowe is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    Sep 2014
    26
    This solved my Front Driver's seat issue ,,, Huge Thanx !!
    Symptom:
  11. #10
    bumboy is offline Cadillac Owners Member
    Automobile(s): Escalade
    Aug 2013
    37
    1
    Hello friends, I have a 2006 Escalade and the forward/backward on the drivers front seat stopped working but everything else still works which includes tilt, bolster/lumbar/heated seats.
    I'm thinking maybe just the forward/backward motor burned up? please help thank you.
  12. #11
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bumboy
    Hello friends, I have a 2006 Escalade and the forward/backward on the drivers front seat stopped working but everything else still works which includes tilt, bolster/lumbar/heated seats. I'm thinking maybe just the forward/backward motor burned up? please help thank you.
    Pull the harness for the motor and carefully apply 12 volts to the terminals (there is two plugs one for the motor and one for the position sensor)
    Either way the whole seat track has to be replaced
  13. #12
    goodpl23 is offline Cadillac Owners Member
    Automobile(s): 07 Escalade ESV
    Nov 2014
    38
    22
    Hello friends, 2007 esv driver seat stopped working suddenly along with brake pedal wont adjust. Also no heat or cool to either seat. However passenger seat does move fwd bckwd up/down. Any suggestions.
  14. #13
    Mar 2011
    speedwell tn,
    11,884
    ^check the connections at the driver's seat module(under the front of the driver's seat)
    Also check the wiring for any chafing or damaged spots
    If the connections and wiring check out then you may have to replace the seat module(as the pedal controls work through it)
  15. #14
    Nov 2014
    38
    22
    Quote Originally Posted by the cadillac man View Post
    Okay great. I will check thanks. Crazy thing is that took it to local dealer and they told me i needed some computer module to fix this. Quote of 2000. I hladly declined.
  16. #15
    Mar 2011
    speedwell tn,
    11,884
    that is highway robbery
    I have priced the seat module and it's nowhere near that(even with labor)
    I would go somewhere else
    It's possible you can get one at a junk yard or salvage yard for a LOT less as it doesn't really need to be programmed to the truck as long as the doner truck has the same features(a Yukon Denali module will work)
  • You may not post replies
