Results 1 to 6 of 6
Thread: 04 Escalade speedometer needle bouncing. What causes it? How to fix it?
    chrischelle is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    Jul 2012
    California
    14
    04 Escalade speedometer needle bouncing. Any others instruments gauges work fine. After replaced stepper motor, it still jumping around. Did not solve the problem!
    Any suggestion of how to fix it will greatly appreciated.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by chrischelle
    It could be a bad cluster.
    Jul 2012
    California
    14
    Re: 04 Escalade speedometer needle bouncing. What causes it? How to fix it?
    I just found out the problem with speedometer needle bouncing. It had something related to new Kenwood (DNX6990HD) head unit I just installed. If I remove radio fuse out of the fuse box.Then speedometer woks just fine, no jerking at all. When I put radio fuse back, needle goes crazy again.
    Any suggestion of how to fix this, I thank you very much in advance.
  5. #4
    Mar 2011
    speedwell tn,
    11,884
    Does your radio tap into the speed sensor by any chance? Sounds like the radio connections or the interface.
  6. #5
    Jul 2012
    California
    14
    Thank you very much "the cadillac man"...You hit a nail right on its head. I disconnected VSS (speed sensor) wire from AXXESS-GMOS-100 and Kenwood DNX6990HD head unit.
    Everything works perfectly. Speedometer needle stay steady as it should be.
    You're the man! Thanks again.
  7. #6
    Mar 2011
    speedwell tn,
    11,884
    Glad to help,
    most time the vss (speed sensor) wire is used for certain feature depending the radio some use it for gps when it ain't getting a signal and rarely auto volume but you won't notice it anyway.
  • You may not post replies
