Sevice Stability System inmessage center, and P0449 code
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Sevice Stability System inmessage center, and P0449 code in Cadillac Escalade Forums; The message center in my 2002 Escalade shows a Service Stability System warning. Theonly code displayed is P0449, which is ...
    hcubed is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Feb 2009
    72
    The message center in my 2002 Escalade shows a Service Stability System warning. Theonly code displayed is P0449, which is for the evaporative emission control system vent valve/solenoid curcuit malfunction.
    No other codes are present. I can erase the code, and the OBD II shows no codes present or pending.
    I replaced the intake manifold mounted vent solenoid yesterday, but it made no difference. The P0449 code would come back up, and the message center warning would repeat.
    The brakes and throttle are not affected at all. The car drives and operates correctly, regardless of the code and warning.
    I can stop at the side of the road, shut the engine off, restart and drive for various distances, feet or sometimes miles before the message center warning reappears.
    Whats up? Any ideas from an expert?
    Thanks in advance
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by hcubed
    Thanks in advance
    I'd say the solenoid is failing which will need replacing.
    Feb 2009
    72
    Re: Sevice Stability System inmessage center, and P0449 code
    As I stated in my first post, I replaced the solenoid yesterday, and it did no good. Brand new solenoid, $50.00 worth......no joy.
    Is the one you are referring to the one mounted just behind the throttle body on the intake manifold?
    Mar 2011
    speedwell tn,
    11,884
    Nope the evap canister is under the truck that is the area you need to be checking.
    Feb 2009
    72
    Sorry, but you guys had it wrong.
    The wiring for the evap cannister solenoid valve that I changed under the hood had been chewed in half by a squirrel or other rodent. Fixed the damaged wires, erased the code and all is well.
    Mar 2011
    speedwell tn,
    11,884
    The wiring for the evap cannister solenoid valve that I changed under the hood had been chewed in half by a squirrel or other rodent. fixed the damaged wires, erased the code and all is well.
    Ok that was a bit odd but at least you got it fixed.
  9. Remove Advertisements
