2000 5.7 vortec blown heads
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2000 5.7 vortec blown heads in Cadillac Escalade Forums; Was just wondering if I can use a different block from a different GM truck or do I have to ...
    clement g hill is offline Cadillac Owners Member
    Automobile(s): 2000 escalade
    Aug 2012
    31
    Was just wondering if I can use a different block from a different GM truck or do I have to use one from a different escalade. I would like to use a used block and wanted to know before I do all this work hopefully the 5.7 vortec are the same
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,833
    Re: 2000 5.7 vortec blown heads
    All year Vortech will work....all the same. You state blown heads in the title....can you explain? Head gaskets can go bad, but never seen blown heads....
    Aug 2012
    31
    I'm sorry the head gaskets blew 3 4 5 and 6 have zero psi I m going to try to do the gaskets first but if thats a no go I'm just going to do a moter swap but wanted to be ready with the info thank you
    TLMC is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade 1969 ss396 chevelle 1967 GTO
    Nov 2011
    BOYNTON BEACH,FL
    63
    76
    sounds like it got pretty hot better have the heads checked for cracks
    sprink60's Avatar
    sprink60 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Aug 2012
    West Palm Beach, Fl
    234
    All Vortecs will work. Your best option if the gasket deal doesn't work is a Vortec Long block from any number of sources. I have 2: L31 4: Bolt Main based Vortecs with Comp Cams Rollers going in my 26' formula in a few weeks. If you swap it's pretty easy to get 400 horse and 425 ft lbs of torque with out getting into exotic stuff with a Vortec...lot of bang for the buck.
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,833
    good advice sprink.
    On the heads you have (assuming they are the aluminum ones) have a machine shop check for warpage and barely resurface taking as little off as possible, but fresh rebuilt vortechs are very afforadble as a long block.
  9. Remove Advertisements
