AC Clutch / Compressor
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, AC Clutch / Compressor in Cadillac Escalade Forums; Has anyone here replaced their AC Compressor or compressor clutch. I think my compressor clutch is going bad. AC still ...
    BDuncan is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    233
    Has anyone here replaced their AC Compressor or compressor clutch. I think my compressor clutch is going bad. AC still works fine but I feel a slight vibration at idle if the AC is on - only noticed this in the past few days and I did drive in horrendous rain and splashing rain water last week. Not sure if it's a clutch or clutch bearing issue or actually the comopressor. Apprecaite anyone's experience with these parts.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by BDuncan
    Mine does the slight vibration at idle but I haven't had no problems with the a/c but If it was the bearings failing it would really fight the engine and try to kill the engine as you are driving
    But I do notice sometimes after I drive in rain the compressor makes a loud boom before engaging which it won't do it other times so it may be the clutch getting wet causing it to slip a bit
    And my truck is 03.
    Nov 2007
    233
    Re: AC Clutch / Compressor
    Cadillac man, mine is an '03 also, 140,000 miles. I have never had this vibration at idle before now - always so smooth you can't tell it's running. With the compressor mounted so low it can certainly get tons of water in heavy rain - may have nothing to do with it but that's when I noticed the vibration.
    Mar 2011
    speedwell tn,
    11,884
    When was the last time you had the throttle body cleaned? as mine tends to do this the most when it needs cleaning cause I recently replaced mine and haven't had this issue show much and lately I drove in some really heavy rain(to the point I was only able to see by my fog lights) and it didn't act up afterward.
    I had to replace mine because it was lagging in response(I don't know If it was cause of the PCM or not which I had to replace lately also) I figured with over 143,000 miles it was getting worn out and the truck idles so smooth I have had to check the tach to make sure it was running also it responds better then it did before.
  7. Remove Advertisements
