2004 EXT Traction Active Problem
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2004 EXT Traction Active Problem in Cadillac Escalade Forums; I put a heavy load in the bed of the truck yesterday and now the the Traction Active keeps coming ...
    ReaganGentri is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade EXT
    Jul 2012
    1
    I put a heavy load in the bed of the truck yesterday and now the the Traction Active keeps coming on when I try to accelerate slowly from a stop. The truck won't go at all! I do have two different tires in the front then the back but hasnt been a problem before. (same size 24's, just different brand) The front two tires are a little worn. I have seen multiple solutions for this problem. The problem is very scary because the tires are not slipping and the road is not slippery or not sandy. Just does it every time I try to stop then go. Could it be the worn tires in the fornt? Should replacing them solve the problem? This is very annoying in traffic!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by ReaganGentri
    Sounds like a wheel sensor failing and causing the traction control system to engage.
    zapconj is offline Cadillac Owners Member
    Automobile(s): 2007 STS4
    Sep 2011
    Northeast
    38
    I had the same thing happen to my 04 ext. took it in for service and it was the front traction sensors located in the hubs. Had both replaced and all is good.
    I was getting the service stabilitrack and random traction active triggers. It almost got me in a few good accidents.
    Mar 2011
    speedwell tn,
    11,884
    Re: 2004 EXT Traction Active Problem
    try turning off the stabilitrack system to see if the problem goes away.
  7. Remove Advertisements
