engine codes after deep water
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, engine codes after deep water in Cadillac Escalade Forums; We had a lot of rain last week and the roads flooded. I had to drive in a couple feet ...
    whosurpopi is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2008
    120
    We had a lot of rain last week and the roads flooded. I had to drive in a couple feet of water and two knock sensor codes came up, and the truck runs very rough when maintaining speeds, but feels fine excellerating or idling. The codes were 327 and I think 334 the book gave the same meaning for both, low voltage to knock sensors. What is the fix for this?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: engine codes after deep water
    i'd say if i am not mistaken that the water got into the knock sensors and shorted them, i suggest you also check out your diff fluid also cause water might have got into there also just to be safe.
    Nov 2008
    120
    Would the sensors make the truck run rough from 40 to 50 MPH or would what ever is making the truck run rough cause the sensors to activate?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by whosurpopi
    Yes it would make the truck run rough the best way to find out for sure is go to a dealer to sure it didn't short out something else.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    I'm betting your engine swallowed some water and the resulting hydro-lock bent a couple of connecting rods. Your engine is toast.
    Nov 2008
    120
    Well that doesn't sound very encouraging. I just bought oil, filter, air filter and plugs along with seafoam. Will try that in the am. I would think if the rods were bent I would feel it on excelleration.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    I'm assuming the engine didn't lock up. In which case it would be one or two rods mildly bent. The usual result is after a while either the crankshaft breaks or it throws a rod. If it's bad enough to affect the running it won't last long. Hopefully, maybe it is just some water trapped some where.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by dkozloski View Post
    that would be a bit hard to do if it is just 2 feet of water due to where the air box placement is which is as close to the top of the fender as possible.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Quote Originally Posted by the cadillac man View Post
    Water splashs and sprays. It's never a good idea to drive down a flooded street.
    Mar 2011
    speedwell tn,
    11,884
    I will agree with you there but I have driven in water covered roads but I do it slowly as to prevent stuff like this from happening although there are some times I just won't try it.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    There have been some previous similar threads involving driving in deep water and the final result turned out to be hydraulic lock. It only takes a half a cup of water in the wrong place and the damage is done.
    Mar 2011
    speedwell tn,
    11,884
    i know about what hydro lock does to a engine i have a glow engine powered rc car and if the engine gets flooded it is at risk of damaging it so i know water isn't a good thing at all to a engine and yes i know when i drive in deep water i am risking the engine in my truck but back to the op if he did in fact bend a connecting rod it can be replaced cheaper then a whole engine.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    The problem is that the cankshaft is often bent and is the first thing to break right at a rod journal in the fillet.
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    WOW that can get pricey
  17. #15
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Here's hoping it's just some water in the wrong place and no mechanical damage. Maybe the guy should trade for an Amphicar. http://www.google.com/url?sa=t&rct=j...SB3aKxjSNO50OQ
  18. Remove Advertisements
