HID problem
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, HID problem in Cadillac Escalade Forums; I got a 2002 Escalade and i replaced the factory headlights with HID headlights..Well the problem is that when i ...
    mskittrell05 is offline Cadillac Owners Member
    May 2004
    97
    HID problem
    I got a 2002 Escalade and i replaced the factory headlights with HID headlights..Well the problem is that when i start my car the headlights flicker as its starting and when the car is started sometimes one of the headlights is off..So i have to restart my car..I contacted a local car shop around here and they said the HID"s are extremely sensitive to voltage drops so thats why i'm experiencing flickering and sometimes a missing headlight...any info on a way to fix this problem or to deal with it besides always restarting my car?
    fast66's Avatar
    fast66 is offline Cadillac Owners Connoisseur
    Automobile(s): Escalade EXT
    Aug 2003
    858, SoCal, Kuwait
    33
    2,294
    Re: HID problem
    Quote Originally Posted by mskittrell05
    you could just turn your headlights off then on again. dont need to turn the car off.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,274
    Re: HID problem
    On my cars and trucks that did not come with HID from the factory I always added a HD headlight wiring harness and connected it from the battery to prevent any voltage drops, I went through hell on one of my Grand Cherokee's until I added the aftermarket harness, I would have trouble getting both light to come on, I would have to turn the headlight switch a few times to get them both to fire up. What manufacturer HID bulbs do you have?
  5. #4
    ICEMAN is offline Cadillac Owners Member
    Apr 2004
    Calif
    81
    Re: HID problem
    HCVONE,
    Who did you go with for the aftermarket HID wiring harness?
    I purchased a HID foglamp conversion from a member here and it works great.
    However it is using the stock wiring to get it's power..I had to increase the fuse from 15 amp to 20 amp.
    However I don't want to burn out my stock harness..perhaps a aftermarket will help out and I can keep my stock equipment intact.
    Any direction is appreciated..
    Larry
  6. #5
    99 SKALAID's Avatar
    99 SKALAID is offline Cadillac Owners Fanatic
    Feb 2004
    california
    36
    376
    Re: HID problem
    sounds like a bad ground to me
  7. #6
    bigred is offline Cadillac Owners Fanatic
    Automobile(s): 1999 STS, 2010 CTS Sport Wagon
    May 2004
    Wilsonville, OR
    329
    Re: HID problem
    Quote Originally Posted by ICEMAN
    HCVONE,
    However I don't want to burn out my stock harness...Larry
    If you have a Philips LV212 ballast, the maximum current the unit is designed to draw is 20A. Like a fluorescent light, HIDs draw a much greater current but only for a second or few when they first start. At 12.4V the ballast will rarely draw more than 14A & that's just for a second or so. It typically cruises at 3 to 3.2A. The only time you're ever drawing more current than the stock wiring is designed to carry is if it's really cold or your battery is getting weak.
  8. Remove Advertisements
