Speedometer Problems
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Speedometer Problems in Cadillac Escalade Forums; I have an old (2003) Escalade ESV For probably 3 months, the speedometer registers higher than the actual speed. At ...
    Jagdad is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade ESV
    Jun 2012
    For probably 3 months, the speedometer registers higher than the actual speed. At first it was only a little. then gradually got worse. At highway speeds now, the speedometer pegs over 120MPH.
    For the experts, a couple of questions:
    1. Is this speedometer strictly electronic and the signal to the dash from a computer somewhere else.
    2. If it is, there must be a sending unit somewhere
    3. Can I check anything to determine whether which part is bad, ie., sending unit or dash unit?
    4. If it is the dash, can I use a junkyard replacement or is it locked some way to prevent mileage tampering?
    Thanks in advance for any help
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    348
    Re: Speedometer Problems
    Search for stepper motor click link
    http://www.cadillacforums.com/forums...er-issues.html
