Engine won't start...once every 2 months???
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Engine won't start...once every 2 months??? in Cadillac Escalade Forums; I have a 2005 Cadillac Escalade, and about once every two months, the engine cranks over and then turns off ...
    NJLivingston is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Jun 2012
    I have a 2005 Cadillac Escalade, and about once every two months, the engine cranks over and then turns off immediately.... At the same time, the power locks, windows, radio, etc. all stop working as well. 1st time, dealer could find nothing wrong, said they charged battery and it was fine for 6 weeks. Second time, they tore out an aftermarket viper alarm system, and charged me $700 for labor and 2 new keys. Now, two months later, it happened again!!! (Obviously it wasn't the alarm!) My husband disconnected the battery negative cable and connected his battery (negative cable) and it started right up and has been working for a few days. Dropped it off at the dealer and they are once again looking into it...but don't seem to have a clue...any ideas?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by NJLivingston
    It sounds like a wire is loose or the truck body module has got shorted cause the locks windows ,radio along a few other options are worked by it given how it acting up (ps do you still have the aftermarket alarm or not?)
    Jun 2012
    Re: Engine won't start...once every 2 months???
    No, I did not get the alarm after it was removed as it was assumed it was not working properly...I now realize that was probably silly on my part...are you referring to a loose grounding strap?
    Mar 2011
    speedwell tn,
    11,884
    Check all of the wiring at the truck body controller under your dash on the driver's side if there is any bare wires exposed it will and can short out and cause some really crazy crap to happen which could have been unrelated to the alarm(this is the most likely place a alarm is tapped into because it has most of the needed wiring close)if you see any bare wires tape them up one by one to see if it helps,
    Now if you don't see any bare wires then something has messed up the truck body controller due to a wire or internal short the later means the tbc module will need replacing.
    P.s it was silly to let the dealer keep the alarm because whoever got it out can just resale it and make a profit on something that might not have been your problem in the first place,
    Unless it is needed to be turned in for a core charge the dealer shouldn't have kept the alarm because it wasn't a dealer sourced part I know because I had to have my PCM replaced and they had to keep the old one but a aftermarket alarm is not a dealer sourced part.
  7. Remove Advertisements
