Results 1 to 7 of 7
Thread: 2006 escalade rear climate control not operating
    Estevecollins is offline Cadillac Owners Member
    Automobile(s): 2006 escalade
    Jun 2012
    67
    2006 rear climate control not operating
    mitch2264's Avatar
    mitch2264 is offline Cadillac Owners Member
    Automobile(s): Cadillac Escalade Platinum
    Dec 2007
    ATL
    79
    Re: 2006 escalade rear climate control not operating
    Is it working from the master control above the rearview mirror? If it is, is the rear turned on from the master controller? If all is set to work from the master control, is anything showing up in the LCD HVAC display for the rear? If all is working to that point, then I would suspect fuse, blower resister or blower motor.
    Good luck!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by mitch2264
    Good luck!
    I hate to correct you but there is no blower resister only modules on both front and rear hvac controls
    But to the op if no response from the system using the rear controls then it is one of two the fuse or someone has disabled them using the front controls.
    I know mine has modules for the hvac and it is 03.
  5. #4
    mitch2264's Avatar
    Dec 2007
    ATL
    79
    That's right--sorry! GM went with a module instead of a resistor in the "auto-climate" vehicles. It is a resistor in the manual control systems.
  6. #5
    Mar 2011
    speedwell tn,
    11,884
    it depends on the year I know cause my previous car had module controlled hvac system regardless of it being auto climate or Manuel controls I know my Mom's 98 chrysler town&country minivan has manual control system and it is module controlled.
    So yes it can be controlled by a module even with the manual control systems.
  7. #6
    Jun 2012
    67
    Front climate control works just find, rear not at all from either front or rear controls
  8. #7
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Estevecollins
    It may be the hvac module in the system which is in the rear behind the trim panel cost for it will be about 100.00 bucks to get a new one and you can do the work yourself using my how-to in the FAQ section of the forum.
  • You may not post replies
