Trans fluid leak
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Trans fluid leak in Cadillac Escalade Forums; My 05 Escalade seems to vent some Trans fluid when the outside temp is over 90 degrees. The Trans fluid ...
    jacob9582 is offline Cadillac Owners Member
    Feb 2012
    89
    Trans fluid leak
    My 05 Escalade seems to vent some Trans fluid when the outside temp is over 90 degrees. The Trans fluid level is in the safe zone and temps are always normal. I had a friends shop test the Trans with their computer to test for any small slippage and non was found. Any help would be much appreciated.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: Trans fluid leak
    sounds like it has been overfilled causing this.
    always check the trans fluid after the truck has been running for a little bit and the trans fluid is up to normal temp.
    Feb 2012
    89
    Check the Trans fluid level with the fluid hot and it is @ the top of the normal range....any other ideas?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jacob9582
    Keep a close check on it If you can look under your truck to see if the tranny doesn't have a seal going bad you can tell by seeing wet spots on the tranny near the seals if you don't have a bad seal then it may be normal not sure though.
  7. Remove Advertisements
