3rd brake light!
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 3rd brake light! in Cadillac Escalade Forums; the third brake light only 1/3 works? could that be a short or fuse because i dont think the whole ...
    bmiller is offline Cadillac Owners Member
    Automobile(s): 2005 escalade esv
    Jun 2012
    ohio
    48
    3rd brake light!
    the third brake light only 1/3 works? could that be a short or fuse because i dont think the whole light bar needs replaced? 2005 escalade esv
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,117
    Re: 3rd brake light!
    Yes, the complete bar is replaced. It's a internal problem with the lamp. Serviced lamps with warranty are available at ledfix.com .
    Being the lamp is lighting up some...the fuse is ok and the vehicle wiring is ok.
    IF the lamp is not lighting up at all...be sure to check the fuse. The CHMSL lamp is on a different fused circuit then the lower tail lamps. Plus the CHMSL shares the same fuse with the trailer hitch wiring...
    On 2002's..check fuse #16 in the underhood junction block.
    On 2003 and latter...check the 'VEH CHMSL' fuse in the drivers side dash board fuse block.
