Would my backup sensor system go nuts if I tapped into the pass. backup bulb?
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Would my backup sensor system go nuts if I tapped into the pass. backup bulb? in Cadillac Escalade Forums; I used the positive wire to provide voltage for a reverse trigger for a backup camera system I just installed ...
    Sentinelist's Avatar
    Sentinelist is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade ESV, Black Raven/black, Platinum wheels, 97k
    Mar 2012
    Dallas, TX
    117
    I used the positive wire to provide voltage for a reverse trigger for a backup camera system I just installed (a few pics and lots of successful info forthcoming if you're following that thread). Ever since I started carefully disassembling several interior trim pieces, whenever the ESV is in reverse, the backup sensor lights all flash on and the chime starts immediately donging like it's about to hit something- the full tilt last pattern tone. Ahhhhhhh!
    The only thing I can come up with is the system is shorting out because I tapped the passenger side taillamp assy. for the positive backup lamp wire. If it's not a secure connection, I wonder if that's the cause. It was doing this before that tap was even connected to anything on the other end in the dash. Ideas?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: Would my backup sensor system go nuts if I tapped into the pass. backup bulb?
    highly unlikely because i installed my back-up camera system by powering it off of the back-up light circuit sounds like the sensors need cleaning unless one of the sensors has gone nutty
    Mar 2012
    Dallas, TX
    117
    Thanks. Happened pretty much at the same time I hooked the whole thing up, so I don't think it's coincidence.
    Are there any controllers for this behind the pass. rear cargo panel where the 12V power point is? I had to pull this out a bit to tap that for the camera's power... pulled down the D-pillar trim as well.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Sentinelist
    I know on mine the rear park assist sensor module is under the second row passenger seat there is a test harness next to it about three inches away.
    osure is offline Cadillac Owners Member
    Automobile(s): 2005 escalade
    Apr 2012
    mpls,mn
    46
    89
    Do you have hitch on? That will do it
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by osure
    It depends on the type of hitch cause I have had my hitch in and never had it my the park assent go nuts.
    Mar 2012
    Dallas, TX
    117
    No hitch, haven't touched the 2nd row seats... any other thoughts? I'm pretty sure it's something behind that panel in the back I may have knocked loose. Haven't had a chance to crack it back open yet.
    Apr 2012
    mpls,mn
    46
    89
    Have you looked at the sensors? I would think it was one of hem that is going nuts. Nothing on the bulb should do that
    Mar 2011
    speedwell tn,
    11,884
    If you can get to the module for the park asset then you can run the test mode and see if you have a sensor that has failed.
    Mar 2012
    Dallas, TX
    117
    Quote Originally Posted by osure View Post
    I can look at them, and they're there- what can I do to test them?
    Quote Originally Posted by the cadillac man View Post
    Please advise how.
  13. Remove Advertisements
