2002 EXT Steering Problems / Grinding when turning
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2002 EXT Steering Problems / Grinding when turning in Cadillac Escalade Forums; ...
    Alex.King is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade EXT
    Jun 2012
    57
    1
    Iíd like help in trying to correct a long-standing problem Iíve had with my 2002 Escalade EXT regarding the steering. There is grinding and clunking when turning. It sounds and feels like the front end will fall apart.
    I've seen reference to Safety Report #000235003: FAILED STEERING . CLUNKING NOISE UNDER HOOD AND CAN BE FELT IN STEERING WHEEL.
    Iíve had it worked on a number of times by two Cadillac dealerships, but continues to have the same problem. What can I do?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: 2002 EXT Steering Problems / Grinding when turning
    has the shaft been replaced???
    i can't think of the name but it is the one the goes between the steering wheel and the steering gearbox.
    bann512 is offline Cadillac Owners Member
    Mar 2013
    47
    Where you able to find anything out or get this issue resolved? I am having somewhat of the same problem and after taking it to several places, no one seems to know what is going on. I thought it was coming from my front tires but everything seems has checked out ok. Also, mine seems to only do it after driving for an extended period of time, like an hour or so. Does this happen to you at all?
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bann512
    Have the steering intermediate shaft replaced that is what is causing the clunk in the steering
    Fox2boost is offline Cadillac Owners Member
    Automobile(s): 04 ext lade
    Feb 2013
    31
    14
    Have you checked the wheel bearing ?
    Feb 2013
    31
    14
    Just replaced mine with a new timkin and no more clunking while turning or hitting a bump. After I mistakinly changed the front a arm I might add.
    TMoNeE is offline Cadillac Owners Member
    Automobile(s): NONE
    Mar 2009
    4
    Quote Originally Posted by Fox2boost View Post
    Did you do it yourself?
    If not, is there a DIY guide?
  10. Remove Advertisements
