Self leveling system problems on 2003 ecalade
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Self leveling system problems on 2003 ecalade in Cadillac Escalade Forums; Team, The leveling system on my 03 escalade keeps running repeatedly. I initially though it was leaking but now it ...
    azaskew is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Feb 2010
    43
    21
    Team,
    The leveling system on my 03 escalade keeps running repeatedly. I initially though it was leaking but now it does not seem to be leaking, it just runs repeatedly. There is no load and it appears to be pumped all the way up...
    Please help...
    azaskew
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by azaskew View Post
    Team,
    Please help...
    azaskew
    There is a auto leveling sensor on either side of the vehicle that are positioned directly inside of the rear tires. The sensor is a round plastic dial approx. 2 inches in diameter with an arm. From that arm extends a small metal post (approx. 3 inches long) with rubber boots on both ends that connect it to the rear suspension arm. You will probably need to take the rear wheels off to see them, but you should check to see that they are both connected properly. If they both look correct then there is a good chance that one or both of these sensors are bad and will need to be replaced.
    Feb 2010
    43
    21
    Re: Self leveling system problems on 2003 ecalade
    Thanks for the great info!
    Do you know off hand how I check these? also do you know how much these might cost.
    Thanks again,
    azaskew
    mikedyk43's Avatar
    Sep 2011
    Mission Viejo, CA
    38
    470
    Thanks again,
    azaskew
    I'm pretty sure these are simply potentiometers. There should be two wires to it, one with a constant voltage in and the other with a varying voltage out depending on the position of the sensor. I could be wrong though, so look into it more. I found a used one for sale on eBay at $150.
    http://www.ebay.com/itm/00-04-SUBURB...34b961&vxp=mtr
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Thanks again,
    azaskew
    the only way to check the sensors on the air shock system along with the ones in the front is with the tech-2 at the dealer. if you want to see on the price call a few dealers to get the price.
  8. Remove Advertisements
