Tire monitor 04 escalade esv
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Tire monitor 04 escalade esv in Cadillac Escalade Forums; Tire Monitor service keeps popping up on dash .. What is the fix ?...
    PearlCaddy04 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV
    Apr 2012
    12
    glover is offline Cadillac Owners Member
    Feb 2012
    26
    Usually needs a tire pressure sensor
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,299
    Re: Tire monitor 04 escalade esv
    moved from cust svc
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    try the relearn process to see which sensor is bad most of the time it is cause of the battery in the sensor dyeing from age.
    Apr 2012
    12
    Thanx for the info .. And whr is the thee Tire sensor in the 04 escalade ?
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by PearlCaddy04 View Post
    It is inside the tire attached to the back side of the valve stem. Yes, if you want to replace them, you must dismount the tires from the rims to do it.
    Apr 2012
    12
    Ok .. Thank u !
    zapconj is offline Cadillac Owners Member
    Automobile(s): 2007 STS4
    Sep 2011
    Northeast
    38
    i had the same problem with my wife's sts4 and found the "Orange Electronics" sensors on Amazon for like $35ea. vs the $100 GM. I have had them installed for the past year and they are working great.... the RELEARN was alittle of a pain but i got the car to link to them eventually.
    Apr 2012
    12
    Zap thanx ..! So all four tires' sensors have to be changed or which ever sensor is needing the work ??
  12. Remove Advertisements
