gas smell - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, gas smell in Cadillac Escalade Forums; So changing the pump should be my first step?...
  1. #16
    Je357 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Sep 2012
    Lond island NY
    35
    61
    Re: gas smell
  2. #17
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Je357
    Should be but there is a sensor mounted on the pump and it can get damaged and cause the fuel smell
  3. #18
    05esc is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Jan 2012
    Re: gas smell
    Hey guys....i also have an 05 and i had the same thing happen. What is most likely the problem is the metal fuel line coming out of the fuel tank. Its one of the only metal sections of fuel line. Only about 3 or 4 inches and then connects to a plastic line. That is probably rotted. and gas is pooling on top of the tank. Unfortunately the whole fuel pump assembly will have to be replaced. Its all one piece with pump, filter,float, pressure sensor, etc. Thats why it now takes a few cranks to start the engine. It will only get worse and start leaving puddles. I replaced mine myself - got one from the dealer....cost me around $500! Wasn't happy. Still wondering what they would have charged if i had them do it.
  5. #19
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,640
    Re: gas smell
    First thing I replace when I begin smelling gasoline but do not detect any leaks is the fuel cap, especially if it is building an excessive amount of pressure. Cheap and easy.
  6. #20
    Sep 2012
    Lond island NY
    35
    61
    Re: gas smell
    Really .......is that line visible. Or do i have to drop tank to inspect. I still havent fix this fuel smell issue.
    Quote Originally Posted by 05esc View Post
    Is this fuel line visible without dropping the tank? Also im getting no check engine light from this problem. So what do ya think. This fuel smell is annoying.
  7. #21
    Donna Lennox is offline Cadillac Owners Member
    Automobile(s): Escalade 2005
    Jun 2014
    Cincinnati, OH
    1
    Re: gas smell
    I am experiencing the same exact thing with my "05 escalade, however I smell it strongly on the rear driver side as well. It has gotten so bad I do not park the vehicle inside the garage. It has been so strong when entering the garage in the mornings that I thought if a spark would flash it might blow up. Have changed gas caps and had 2 mechanics look at it. Of course there was no odor when I got to them, however as soon as I returned home it was back and stronger. Have you been able to discover the problem?
  8. #22
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Donna Lennox
    Crawl under there and see if you can see gas on the tank
    There is a sensor on top of the fuel pump that if broken will cause a strong gas smell(went through this same problem with my mom's 02)
    Have the truck on a level surface and work the key a few times to see of there is a leak
    Or just park on a steep hill(the gas will do the rest)
  9. #23
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    Re: gas smell
    Quote Originally Posted by phattruk View Post
    i'm still annoyed that my truck was 2 days past warranty and they wouldn't replace my navigation system (every once in a while i get disc error and need to turn truck off and on a few time to get it back)
    As far as this problem you are having, a new nav disc might fix it. I had the same problem out of the blue. Disc looked fine with no scratches (I never remove it from the head unit). The problem was driving me nuts so I tried a different nav disc and the problem stopped.
  10. #24
    praelade is offline Cadillac Owners Member
    Jun 2013
    27
    Re: gas smell
    Just for grins check your EVAP canister. I had the same smell, and when I looked at the EVAP canister, one of the plastic lines had snapped off...
  11. #25
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by praelade
    Also had the same issue on my mom's 02 had a time with the line
  12. Remove Advertisements
