radiator 2004 escalade
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, radiator 2004 escalade in Cadillac Escalade Forums; Is there a drain plug on the radiator of a 2004 escalade, or do I have to take off the ...
    jrwireman1960 is offline Cadillac Owners Member
    Automobile(s): 2010 cts-v,2011 esclade
    Dec 2011
    st louis mo
    75
    16
    Is there a drain plug on the radiator of a 2004 escalade, or do I have to take off the bottom hose to drain it?
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    792
    Re: radiator 2004 escalade
    I'm not sure on the Escalade but I haven't come across a GM vehicle yet that didn't have a drain plug in the radiator. I seem to remember them most of the time being right below the low side return outlet. I did have one vehicle that had an inaccessible drain plug, it was covered up by the sheetmetal under the radiator support. That one required me to pull the lower hose to drain it.
    Trulytex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Black Escalade EXT
    Nov 2010
    Okeechobee, FL
    52
    355
    There is usually a Petcock (drain) on either side of the bottom of the radiator.
  5. #4
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    894
    Funny enough, this past Monday I spent 45 minutes looking for a drain or petcock on our '05 Escalade, I had to replace the water pump. Anyway I could not find one. I have drained many radiators in my wrenching life.
    I have a kiddie pool that I put under the front end and pulled the lower hose to drain.
  6. Remove Advertisements
