2005 cadillac escalade platinum what is going on with this thing
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2005 cadillac escalade platinum what is going on with this thing in Cadillac Escalade Forums; OK, I had new wheel bearings new everyting put in fron of vehicle. Everything. So every once in a while ...
    kycop is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade ESV Platinum Edition
    Apr 2009
    kentucky
    42
    53
    OK, I had new wheel bearings new everyting put in fron of vehicle. Everything. So every once in a while i will come to a stop sign stop light etc. I stop. then when i goto pull out its like the ABS is activating / or engine is cutting back. I let off gas for a second give it gas again it takes off goes fine. Mechanic has drove it with it hooked up to computer, noting is showing anything is wrong. I told him wheels sensors, they so no it could be fuel pump or something going out because it is cutting power. But this didnt start till had brand new speedsensors front end etc put in...What the heck could it be,,, And if it is speed sensors and its not shownig on computer when being driven, how the heck can they tell what one it is?
    William01's Avatar
    William01 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade ESV
    Jul 2011
    CO
    109
    Re: 2005 cadillac escalade platinum what is going on with this thing
    speed sensors/ABS sensors are the same thing on these trucks I was told. I have also heard that sometimes the sensors are misaligned on the Front hubs, which would cause this. I would suggest this anyone correct me if I'm wrong. first to turn off the Stabilitrac System. I have 03 ESV but the button is right of the URPA button on the right on my truck. You will get a message in the dash saying "STABILITRAC SYSTEM DISABLED". Then take it out and see if you can re-create the problem. My guess is no. In which case it is the speed sensors/abs sensors whatever you want to call them. Either they are bad or they need some realigning. Just my thoughts. Good luck.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    Cheap / bad replacement bearings installed?
    I haven't checked out the Escalade yet but I did replace the front wheel bearings twice on my Trailblazer because I went with cheap eBay wheel bearings. The first cheap set had issues with the speed sensor after only a fe miles. Something inside the hub with the reluctor ring as a new speed sensor didn't help.
    When it comes time to replace on the Escalade I'll make sure I budget for some name brand bearings as it's not something fun to do or pay someone else to do.
    I didn't have stabilitrack on my Trailblazer, but it did create havoc with the ABS system. My scanner showed below 10mph that the wheel was stopped forcing the ABS to kick in, a bit unnerving when you're stopping in traffic and the ABS is fighting you.
