service control module
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, service control module in Cadillac Escalade Forums; Anyone know where it ls located on a 04 Escalade?...
    jrwireman1960 is offline Cadillac Owners Member
    Automobile(s): 2010 cts-v,2011 esclade
    Dec 2011
    st louis mo
    75
    16
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jrwireman1960
    What control module are you needing the location of?
    Dec 2011
    st louis mo
    75
    16
    Re: service control module
    I would like to know where the service control module is located on a 04 escalade
    Mar 2011
    speedwell tn,
    11,884
    Are you talking about the ride control message?
    Dec 2011
    st louis mo
    75
    16
    No, I am talking about the service control module, from what I understand it controls the air ride system
    Mar 2011
    speedwell tn,
    11,884
    Most of the time when you get the service ride control it is the compressor needing replaced but I suggest going to the dealer to have the tech-2 connected to the truck to pinpoint where the problem is
    I know mine is giving the service ride control message and it is the exhaust valve on the compressor.
    Dec 2011
    st louis mo
    75
    16
    I can jump the control relay for the compressor and it works fine, what I need to know is what tells the coil of that relay to energize. I read somewhere that the service control module controls the compressor but I can't I can't find this control.
    Mar 2011
    speedwell tn,
    11,884
    Ok if the compressor motor works then it is the exhaust valve solenoid that is bad,
    the only way of fixing that is to replace the compressor unless you are good with working on it and can replace the said part then that can fix the problem.
    Ps most of the time people had a problem with the rear air shocks and compressor it is due to aging and leaky shocks burning the compressor up but I suggest making sure your shocks ain't leaking before you replace the compressor.
    Frances69 is offline Cadillac Owners Member
    Mar 2012
    27
    6
  12. Remove Advertisements
