service ride control
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, service ride control in Cadillac Escalade Forums; I can jump the relay and the compressor works fine, but the compressor will not come on automatically. What control ...
    jrwireman1960 is offline Cadillac Owners Member
    Automobile(s): 2010 cts-v,2011 esclade
    Dec 2011
    st louis mo
    75
    16
    I can jump the relay and the compressor works fine, but the compressor will not come on automatically. What control energizes the coil of the relay,and where is it located. Thanks for any help.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jrwireman1960
    If you are getting a service ride control message that is the reason the compressor won't function without jumping the relay it is most likely a code or two in the module that needs to be seen too before the system will work,
    but before you do anything check the shocks for leaks.
    I suggest using a spray bottle with soapy water soak both shocks really good then work the rear end up and down while looking for bubbles.
