Air ride problem with load after replacing shocks/compressor
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Air ride problem with load after replacing shocks/compressor in Cadillac Escalade Forums; I just replaced both my compressor and both shocks with factory parts. Everything works fine unloaded, I here the compressor ...
    rd snake is offline Cadillac Owners Member
    Automobile(s): none
    Dec 2008
    6
    I just replaced both my compressor and both shocks with factory parts. Everything works fine unloaded, I here the compressor kick on etc. but when I hook up with my trailer, the truck hits the ground. When this happens, I here the compressor kick on but the truck doesn't level correctly. I also felt the shocks, they seemed very firm, like their was air in them. I also checked my leveling bars to see if they are bent but looked correct.
    This one has me stumped. Any ideas?
    Kevin
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    I would suspect an air leak! Given that you just replaced the compressor and shocks, I would check the fittings first and perhaps the air lines if they were reused.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: Air ride problem with load after replacing shocks/compressor
    take some soapy water in a spray bottle and soak the shocks and lines really good cause it sounds like a leak like the previous poster said.
    enger126 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac Escalade
    Oct 2010
    Minnesota
    31
    151
    How much tongue weight does your trailer have?
  7. Remove Advertisements
