Escalade sun visor help
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Escalade sun visor help in Cadillac Escalade Forums; I have bought this car and it came with tvs in the sunvisors and I want them gone. So I ...
    ESCALADE200224's Avatar
    ESCALADE200224 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Jan 2010
    Midwest US
    256
    I have bought this car and it came with tvs in the sunvisors and I want them gone. So I bought a pair of factory ones and need help getting them out. Anyone wanna help me please.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: Escalade sun visor help
    i'd go to a junkyard find some it is cheaper then new plus if you don't want the visors you have now i'll take them off your hands as i need a better monitor for my back-up camera.
    Jan 2010
    Midwest US
    256
    Quote Originally Posted by the cadillac man View Post
    I already got replacement stock visors but I need help taking them out. That's my problem.
  5. #4
    TheCaddyKidd's Avatar
    TheCaddyKidd is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 Cadillac Escalade EXT
    Sep 2003
    New Jersey
    31
    2,090
    Usually with monitors like that you just have to track down where the video cable is.. The other wires are just power/ground.. Did the car come with an aftermarket dvd player?
  6. #5
    Jan 2010
    Midwest US
    256
    Quote Originally Posted by TheCaddyKidd View Post
    Yes it came with a kvt-717dvd. The car had 9 including the Kvt717. I've removed one but need help with the two visors. My problem is that if you look at the pics I posted there's alot of wiring that goes up The a pillar.
  7. #6
    zogg is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade EXT
    Jun 2011
    137
    Would it not be easier to simply cut the wires and leave the remnants in the pillar? If you are trying to save the wires, it should be easy to follow the ones from the monitor and remove only those wires. Be careful as you have wires in there for the lighted mirrors, power sun roof, etc.
  8. #7
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Since it seems that you are not intending on putting these back in, I agree that the easiest method would be dismounting the visors and cutting the wires to the monitors and leave the wires in place. There should be a minimum of three wires for the monitor, a power, a ground and a video input cable. If you decide to leave the wires in place, you need to be sure and tape off the ends of at least the power and video input cables. The video input cable will also likely be two separate wires inside of one sheath, and these two wire ends cannot be touching either or it could distort the picture to any other monitor that shares the same feed. If the installer of these visors was not an idiot, there should also still be the factory connector for the stock visors inside the hole where these are mounted.
  9. #8
    Jan 2010
    Midwest US
    256
    So does anyone know if the ceiling comes down easy or how to do I can get at the wires? I can get to the wiring on the pillar but after that it goes under the ceiling.
  10. #9
    Jan 2010
    Midwest US
    256
    Well I got up there and found the black cord and pulled it and found the grey RCA going to the black as a RCA. So taking it out was a bitch because the previous owner taped every 6 feet behind everything! I got one down and it took one hour to do it and I haven't even gotten all of the cable for the one out yet. I'll post a pic of how long of cable were talking about later when I get the RCA out.
  11. #10
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by ESCALADE200224 View Post
    wow that is a lot of cable i didn't see the part where you mentioned you had already got the stock visors i was worried about my truck being in the shop for a new starter. p.s. as long as there is enough wire to use to extend and the rca connector is intact i don't mind.
  12. Remove Advertisements
