Adding Subwoofer/Amp to 2000 Escalade
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Adding Subwoofer/Amp to 2000 Escalade in Cadillac Escalade Forums; So I'm having trouble finding info on how to add an additional amp and subs to my 2000 escalade. I've ...
    TheMissingLink5 is offline Cadillac Owners Member
    Automobile(s): '99 Escalade
    May 2011
    33
    8
    So I'm having trouble finding info on how to add an additional amp and subs to my 2000 escalade. I've seen the wiring diagram, but am still not sure of where the stock sub/amp is. I also have read there is a harness to attach to the stock harness to give rca out, but can't seem to find where to buy one.
    Any help would be appreciated.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: Adding Subwoofer/Amp to 2000 Escalade
    in the rear just near the stock sub the amp is silver hard to miss once you remove the rear trim piece,
    i don't know of a harness for the 02's and older to add rya outputs but i could wrong on that.
    ESCALADE200224's Avatar
    ESCALADE200224 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Jan 2010
    Midwest US
    256
    Quote Originally Posted by TheMissingLink5 View Post
    Here's what you'll need for rcas:
    http://www.sonicelectronix.com/item_...OEM-GM21A.html
    May 2011
    33
    8
    Thank you both for your replies. The Cadillac Man - I have a 2000, would it be different? Escalade200224 I found that and was wondering if that would be the correct part, I'm glad you're able to confirm it. I'm going to order that right away and then I have to find the disassemble diagram for the front dash again, lol. Unless you know of another simpler way to do it?
    Also, to both of you, I seem to keep reading 2 different locations of the subs, either what you described The Cadillac Man in the back rear panel, but also have read it's under the center console...when I looked through the grate in the back panel it didn't seem to have a speaker inside, so I'm assuming it's in the center console?
    Jan 2010
    Midwest US
    256
    The sub and amp is under the center console if you have a 03 or later. 02s and older have them in the rear driver side panel. Inside there won't look like a speaker. The sub is inside a black box and the amp is on top of that.
    Yes you'll have to open the dash to get to the wiring.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by ESCALADE200224 View Post
    plus i know the amp is sliver as i have seen them before it is sliver even on the 03's and newer one's also and you only have to open the dash if you are installing a new radio cause the amp and sub is in the rear behind the trim piece the sub in a black box and the amp should be on the top or just to the front of the sub's location.
    May 2011
    33
    8
    So I know it's been awhile to this, but I never got around to doing anything. I had to take out bucket from the center console (between the seats) to fix a switch, and pulled off the top. I know the bass comes from the center console (based on vibrations) and I see a black plastic case with a Bose part number on it. I guess they put them in different spots?
    Now to find where the amp is...
    Mykill322 is offline Cadillac Owners Member
    Automobile(s): 02 Escalade
    Jan 2013
    I have a PAC AOEM-GM21A I am not using anymore in my 02, since I upgraded my head unit and had to purchase the PAC ROEM-GM21A. I would check PAC s website to verify the model number you need for a 2000.
    Let me know if you're interested.
    00escalademan Guest
    The sub for 00 is in center and NEWER ONES are in the rear I do auto work
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by 00escalademan
    Your wrong there bud
    The 02 and older has the sub in the rear
    The 03+ has the sub under the center console as I replaced mine with a better aftermarket sub
    Any audio tech will agree with me here
    kses123 is offline Cadillac Owners Member
    Oct 2005
    15
    Let's clear this up here...
    1999-2000 Escalade: Subwoofer & Amp in the center console
    2002 Escalade: Subwoofer and Amp in the rear cargo area on the drivers side
    2002 Escalade EXT: Subwoofer & Amp in the center console
    2003-2006 Escalade/EXT/ESV: Subwoofer & Amp in the center console
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by kses123
    Let's clear this up here... 1999-2000 Escalade: Subwoofer & Amp in the center console 2002 Escalade: Subwoofer and Amp in the rear cargo area on the drivers side 2002 Escalade EXT: Subwoofer & Amp in the center console 2003-2006 Escalade/EXT/ESV: Subwoofer & Amp in the center console
    That is right
    greensmacker's Avatar
    greensmacker is offline Cadillac Owners Member
    Automobile(s): 2003 ESCALADE
    Jan 2014
    10
    Quote Originally Posted by the cadillac man View Post
    your wrong there bud
    the 02 and older has the sub in the rear
    the 03+ has the sub under the center console as i replaced mine with a better aftermarket sub
    any audio tech will agree with me here
    correct sir!!!
  16. Remove Advertisements
