HID aftermarket
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, HID aftermarket in Cadillac Escalade Forums; I had the driver side factory HID on a 2003 escalade light go out. switched lights moved the ballast and ...
    tsmiller6003 is offline Cadillac Owners Member
    Automobile(s): 2007 xlr, 2003 escalade
    Feb 2012
    ExclamationHID aftermarket
    I had the driver side factory HID on a 2003 escalade light go out. switched lights moved the ballast and the light come on and off. returned the bulb the it went out. checked leads seem to be fine. thought I would replace the the whole headlight and ballast with aftermarket HALO's. and the right side went out. switched the bulbs (left and right) and light was still good, seams to be the ballast. I have a new aftermarket ballast but don't want to blow it.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: HID aftermarket
    if the bulb is good then it is in the ballast and it needs replacing before it messes up other things such as the bulb trust me you don't want it to go bad.
    ESCALADE200224's Avatar
    ESCALADE200224 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Jan 2010
    Midwest US
    256
    Be careful with switching ballasts around. I bought my esv it came with two different brands and then one was dying. When mine was dying I was told to have a pair of the same thing and don't have different ones. So I ordered another one that worked from a salvage yard and it works great. Mine were OSRAM and Phillips and the Phillips died. Go figure. But the osram is the original ballast and great things are said about osram. Phillips ones are crap. I also don't recommend those eBay ones.
  5. #4
    Mar 2011
    speedwell tn,
    11,884
    Re: HID aftermarket
    Quote Originally Posted by ESCALADE200224 View Post
    mine has phillips ballasts and they have served me great so far.
  6. #5
    Jan 2010
    Midwest US
    256
    Well I've had one and it was causing damage and others have complained plus they're more expensive then osram ones.
  7. #6
    Mar 2011
    speedwell tn,
    11,884
    Re: HID aftermarket
    i will keep the cost of them in mind if i ever need to get replacements as cost is a factor for me.
  8. Remove Advertisements
