Results 1 to 3 of 3
Thread: 2003 Escalade service air ride warning
    02luxodeville is offline Cadillac Owners Member
    Automobile(s): 2002 Deville DHS
    Mar 2011
    Just replaced the rear air shocks and compressor for a customer of mine with arnott units b/c the old parts were blown. Now the service air ride warning on the dash keeps coming up and I can't figure out why. It isnt sending a DTC to the OBD II and I checked the new parts I installed, they're all working properly. No loose connections w/ hoses or wires from what i can tell. I'm all out of ideas, any help? Thanks!
    mikedyk43's Avatar
    mikedyk43 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Escalade
    Sep 2011
    Mission Viejo, CA
    38
    470
    Quote Originally Posted by 02luxodeville View Post
    I don't know their proper name, but there are potentiometers mounted in between the frame and the rear suspension. Sometimes when the vehicle has the rear suspension fully extended (jacked up until tires are off the ground), one or both of these can rotate to the opposite direction. You can check these out by jacking up the rear by the suspension and removing the rear tires. They are very noticeable once the tires are removed. The wife blew a rear tire once and dislodged one side, took me a while to figure it out, but constant "service air ride message" as well.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: 2003 Escalade service air ride warning
    just a fyi the rear air module can only be probed by a tech-2 device not a code reader like at auto zone.
  • You may not post replies
