2005 escalade fuel filter
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By jnrsesv
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2005 escalade fuel filter in Cadillac Escalade Forums; do i have one? i haven't gotten under it to look, I've read no its all in the tank but ...
    andy9743 is offline Cadillac Owners Member
    Automobile(s): none
    Jan 2012
    35
    16
    do i have one? i haven't gotten under it to look, I've read no its all in the tank but on several parts sites they sell them?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: 2005 escalade fuel filter
    it is not in the tank it is under the driver side front door area you can't miss it all trucks that gm has made so far has it in this spot.
    source my uncle worked at gm plus i have looked under my truck to verify.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    804
    It seems to be that 03 was the last year for the external fuel filter. None of the parts sources I use can even find a listing for an 05. I looked under the driver door and didn't see a filter on mine either.
    enger126 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac Escalade
    Oct 2010
    Minnesota
    31
    151
    My 05 doesn't have one.
    Mar 2011
    speedwell tn,
    11,884
    then it is in the tank then cause all suv's and trucks have a fuel filter somewhere in the system.
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    901
    The fuel filter on an '05 is a strainer that is located on the bottom of the fuel pump inside the tank. I have been told that when one shuts off the engine, any debris will settle down to the bottom of the tank.
    bigirb2002 likes this.
    Automobile(s): none
    Jan 2012
    35
    16
    looked under my 05 while doing a diff/t-case fluid swap and i do not have one either
    Caddie Shak is offline Cadillac Owners Member
    Automobile(s): Hoop-D
    Feb 2012
    SoCal Dreamin'
    34
    Hard to believe that an EFI vehicle doesn't have a real fuel filter somewhere. A strainer in the tank is okay for a '69 Camaro with a carburetor, but not a high-pressure EFI system.
    Feb 2010
    901
    Believe it!
    I know it sucks, I would rather have a filter to change at service intervals.
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,796
    You can always add one along the frame
    NutzAboutBolts is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Escalade
    Jul 2013
    19
    Here's a video to show you how to replace the fuel filter on your 2002-2006 Cadillac Escalade V8 6.0L Engine
    http://www.youtube.com/watch?v=BLGu8jnY0wM
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    Quote Originally Posted by jnrsesv View Post
    U r correct sir. I installed a Delphi pump in my 05. The strainer in the tank actually works well. It's in the fuel pump assembly as one unit. At 130k miles the tank was very clean
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bigirb2002
    They started in 03 as mine has the strainer and no external filter
  16. Remove Advertisements
