Car shakes
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Car shakes in Cadillac Escalade Forums; Hi can any one help my car starts to shake from side to side from about 20 mph its not ...
    PIGLET is offline Cadillac Owners Member
    Automobile(s): 2002 escalade
    Jul 2011
    LEEK STAFFS ENGLAND
    49
    46
    Car shakes
    Hi can any one help my car starts to shake from side to side from about 20 mph its not a violent shake but its there and driving me mad, iv had the wheels balanced, new idler arm, checked prop uj front and rear, new rotors front and rear any help would be great
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Re: Car shakes
    sounds like someone didn't balance one of the wheels right i know as mine does a slight shake like this at 70-75 either that or you have a broke belt or sidewall in one of the tires which means it is defictive.
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,030
    Re: Car shakes
    Did you have the wheels road force balanced?
    The above post is my 2 cents....nothing more.
  5. #4
    zogg is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade EXT
    Jun 2011
    137
    Re: Car shakes
    I am also betting on broken belts int he tires....rotors only cause the wheels to shake during braking.
    Rotate the tires front to rear and if the shaking goes away, you have broken belts in the tires....good luck
  6. #5
    Jul 2011
    LEEK STAFFS ENGLAND
    49
    46
    Re: Car shakes
    thanks i will have the wheels/tyres looked at again the rear tyres are new but the front are not so i will get the front looked at first
  7. #6
    Mar 2011
    speedwell tn,
    11,884
    Re: Car shakes
    Quote Originally Posted by PIGLET View Post
    i'd bet one of the rear tires wasn't balanced right let us know how it comes out.
  8. #7
    Jul 2011
    LEEK STAFFS ENGLAND
    49
    46
    Re: Car shakes
    had wheels rebalanced all ok checked all rear trailing arm bushes they are ok and the panard rod bushes they are ok, there is a small amount of play in the transfer box prop outputs but no more than i would expect, but what ever it is the rear sway bar has now snapped i have removed the sway bar and it still shakes mostly between 20/30 mph any help
  9. #8
    Mar 2011
    speedwell tn,
    11,884
    Re: Car shakes
    that might be the problem i have never had the sway bar snap before but there always a first time try replacing the sway bar with a new one and see if the shaking goes away also if your spare tire is in good shape try it at each side on the rear until you find a culprit something ain't right somewhere.
  10. #9
    Jul 2011
    LEEK STAFFS ENGLAND
    49
    46
    Re: Car shakes
    found the problem the front n/s tyre had a small flat spot on the inside of the tread about 8" long 3" across the tread the guy doing the balancing felt it when he slowed the machine down with his leg then you could see there was less tread in that one spot glad its sorted thanks for all your help
  11. #10
    Mar 2011
    speedwell tn,
    11,884
    Re: Car shakes
    your welcome i am glad to help out anytime.
  12. Remove Advertisements
