05 Escalade - Help replacing the Water Pump
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 05 Escalade - Help replacing the Water Pump in Cadillac Escalade Forums; Has anybody done this before? Anything I need to be aware of? I have changed water pumps before but it's ...
    ChadKam is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Apr 2010
    35
    22
    I have changed water pumps before but it's been years. Just want to be prepared when I do it.
    Thanks
    drgheith is offline Cadillac Owners Member
    Automobile(s): escalade
    Jan 2012
    30
    3
    Re: 05 Escalade - Help replacing the Water Pump
    Yes, i just replaced mine yesterday .. Probably the simpliest thing i i have ever done. it was 4 10m bolts(hold waterpump) 3 15mm( tensioner ) an 2 10mm(thermostat) Make sure u clean the area where ur gaskets sit.. a trick i used was a wet vac to suck up the water from the block so i can properly clean it... Im a lil ocd haha but all in all i knocked it out in less than 25min .... If u need any help ill be more than happy to assist u further
    Apr 2010
    35
    22
    Thanks for your response. Maybe a dumb question but did you drain your radiator before taking the pump out and using the wet vac?
  5. #4
    cpmet200's Avatar
    cpmet200 is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac Escalade ESV
    Jul 2011
    80
    check out this video. I know it helped me a lot. Hope it does the same with you
    http://www.youtube.com/watch?v=lHxeqRAjB6A
  6. #5
    Trulytex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Black Escalade EXT
    Nov 2010
    Okeechobee, FL
    52
    355
    Quote Originally Posted by ChadKam View Post
    There is no reason to drain your radiator when changing a water pump, unless you just want to flush your radiator at the same time. I would suggest replacing your thermostat while you're at it, they are cheap.
  7. #6
    zogg is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade EXT
    Jun 2011
    137
    I makes sense to flush he cooling system if you are changing the water pump....seems to me it would be like replacing the oil filter without changing the oil. If I have to tackle the cooling system, I replace everything...belts, hoses, tensioners, etc....now I am good for 50k miles.
  8. #7
    skills2005's Avatar
    skills2005 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Escalade EXT
    Jul 2009
    Houston, TX
    36
    85
    Does anyboy know the torque measurements I'd had to tighten it too tight.... it is aluminum.
  9. Remove Advertisements
